Question about Vivitar 5000AF Multimedia Projector
Need new cycle switch
I bought a brand new vivitar 5000AF slide projector and it does not cycle correctly. There is a leaf switch internal to the machine that is staying closed. I am simply looking for a part number / availability
  • 442 Answers
This switch is generic to other models so ask the agent for a spare
Posted on Mar 03, 2011
My kodak carousel 5600 slide projector wont stop advancing unless i unplug it
You are experiencing a fairly common problem called continuous cycling. It is caused by use or mis-adjustment.
If you feel comfortable with a electro-mechanical adjustment, take a look at the attached picture for the correct alignment of the cycle contacts. The positioning is critical for correct operation.
Turn the projector upside down (unplugged), and remove the bottom screws. Then carefully remove the bottom cover. The cycle contact assembly will be in the center of the projector.
If you need help, contact a authorized repair dealer. Good Luck!!
Jun 21, 2011 | Kodak Carousel 5600 Slide Projector
We want to import goods slide projector
I would recommend Kodak Ektapro 7010, 7020, 9010 or 9020. Great, dependable international machine! Jim
May 03, 2011 | Vivitar V5000AF Slide Projector
I need a rotary carrousel for 3000 AF
Your best bet is the internet - do a Google search for a new or used one. Be sure to be specific on the brand and model of the projector you need the tray to fit. "Carousel" is a Kodak trademark, and someone looking to make a quick buck might assume you can use a Kodak tray on your Vivitar (which we know you can't). And there's still a TON of Kodak trays out there. Good Luck! Jim
Apr 03, 2011 | Vivitar V5000AF Slide Projector
I have Hanimex Rondex 120 rotary magazines. I was told these would work in the Vivitar 5000AF. Is this true, as the slide on mine is jamming on the return?
I have a VIVITAR 5000 AF slide projector.
Occasionally, the slide gets stuck while operating the mechanical hand to change the slide. Most of the time it works when I push the slide carrier by hand. Very very infrequently, the projector actually throws out the slide.
I have ascertained that teh Kodak slides which are mounted on paper frames are much too thin for the mechanical hand pushing teh slide in and out. The solution is to remount teh slides on palstic frames or some how add to the thickness of the slide. I have not tried it yet , though.
Any more ideas?
MNAQUVI@yahoo.com
Jan 23, 2011 | Vivitar V5000AF Slide Projector
Carousel projector slide not working right. Can only see half of the picture on the screen.
I had a similar problem and was able to get the full view by giving the change button a quick touch for a partial activation. It seems as though the cycle does not complete before the motor is turned off at what should be the end of the cycle. I took it apart to find the problem but did not discover the correction. So the little "flick" on the change button finished moving the slide into position and the "blocker panel"(inside the projector)) out of the way so the whole slide could be seen.
Jan 13, 2011 | Vivitar V5000AF Slide Projector
I have just had a new vivitar camera with a li-ion battery i bought a sd card and can only take one picture before the memory is full, have i bought the right card
Did you take any pictures before you bought the card? If so, you have pics on the internal memory and that is what's full. You need to get rid of those in order for your card to work. Here's how...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, you really should do the format thing with the new card, too. Then, it should work properly. Also, make sure the slide switch on the side of the card is in the unlocked position.
Dec 29, 2010 | Vivitar Cameras
Auto focus keeps going in and out of focus
try to turn autofocus feature off or reset the settings.
Mar 05, 2009 | Vivitar 5000AF Multimedia Projector
I can't get the light to come on.
Sounds like your black screen shutter is not opening allowing light to pass through. Try it with the carousel and slides installed. Run a few passes.
Mar 05, 2007 | Vivitar V5000AF Slide Projector
Slide projector autofocus constantly adjusting
My slide has the remote but remote is not working the projector i have is v5000Af
Jan 02, 2007 | Vivitar V5000AF Slide Projector
37 people viewed this question
Top Vivitar Office Equipment & Supplies Experts
bhargav
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Vivitar Office Equipment and Supply Expert? Answer questions, earn points and help others
