Question about Magellan GPS 310 GPS Receiver
Magellan 310 Signal Won't Lock In
When I "Go - To" one of my saved marks i don't seem to be able to get a signal lock. You can see the unit looking for satellites but it won't lock in.
Any suggestions or help will be greatly appreciated.
  • Anonymous Jan 05, 2008
    hi chris here gps 310 finding sats but wont track in to give you exact position
  • 3 Answers
Turn on the power while holding down the right arrow. This will reset the unit. You will have to reset the location, date, and time.
Posted on May 07, 2008
  • roy smith
    roy smith Oct 31, 2013
    save your GO TO coordinates before you reset so you can re enter later after you reset your GPS,
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Washer won't start, dl signal appears
Your unit does not see the door lock circuit, check the door to see is tabs are broken or missing. If you don't see anything broken or missing, replace the door lock. Part number 34001011
Door Lock
You can order this or go to your local part house and get this part you need.
I hope this helps
Aug 14, 2011 | Maytag MAH2400A Front Load Washer
No signal in two units, did reset with magellan tech service, still gets stuck in the same location and no signal
Plug it in, turn it on and let it sit out in the open. If the unit is working at all, it will eventually find and lock onto the satellites. The 760 I'm using now came from California and it took over 2 hours to lock on. When I start a trip now, I let it sit before starting to drive and it locks on in just a few minutes.
Oct 27, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Satellite Lock
i cleared the memory and it seems to work now
you will want to write down the waypoints or any other saved data before doing this
Oct 15, 2008 | Magellan SportTrak Pro GPS Receiver
2002 door locks failed ford escape
Using a multimeter, check for voltage at the lock/unlock solenoid. Disconnect the connector and probe the unlock side with the other lead on a good ground. Hit the unlock twice and see if you get voltage. If yes, the solenoid may be defective or if not, you could possibly have a bad relay. Even though you can hear the relay, that doesn't necessarily mean it's completing the circuit. My car did the same thing and I ended up replacing the relay.
The lock side check would be the same.
Hope this helps!
Aug 31, 2008 | 2004 Ford Escape
No Satilite Signal
it is a dicontinued like mine roadmate700 and started losing sattilite signal like everyone says here ,i got upset i spent alot of money on it,then this happens, so i decided and bought the new magellan mastreo 4000 and just updated the software and no problems i love it,portable,thin light weight internal chargable battery that lasts 3hrs,the signal strenght is awsome,never had any problems,my advice junk it, the 700 like i did and purchase a new unit.this way it will save you alot of problems and headaches in the future,beleive me.
Aug 02, 2008 | Magellan RoadMate 700 GPS Receiver
Turn on the power while holding the right arrow. This resets the unit. You will then have to reset the time, date, and location.
Jan 22, 2008 | Magellan GPS 310 GPS Receiver
GPS not able to lock (SNR often 0, sometime in thee 5-10 range)
Me again...I took the unit apart and found out that there is a coax cable between the back board and the middle board. The cable has plug in connectors (v. small size) and the female connectors are soldered SMT on the boards. They are coming out quite one of them was literally ripped off the board. I soldered it with quite a fine iron,did a reset and I am back in a footnote my readings in AZ /El were all zeros!!!!
May 21, 2007 | Magellan RoadMate 700 GPS Receiver
Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Oct 19, 2006 | Magellan GPS 315 GPS Receiver
Magellan GPS 310 GPS Receiver Logo
336 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
