Question about Toshiba 53H71 53 in. Rear Projection Television
Hi toshiba 43 rp
Hi i have a toshiba 43vj13p, i have a red screen which wont turn down also green and blue lines, my brightness wont turn down either, you can watch tv its just to bright and red any help would be gratefull thanks
  • robert nicholson
    robert nicholson Nov 29, 2007
    sorry its a toshiba 43vj13p 3 years old approx,just to help clarify,the picture is not to bad but is awfull red it can be turned downon the front of tv, but is still too red also brightness is too high have tried turning it down on menu to 0 but again is to high,you can make out the red blue screen lines faintly in back of picture,thanks for any help guys
  • robert nicholson
    robert nicholson Dec 09, 2007
    thanks guy's that did the job changing the red crt,now i have a slight bow on the new red crt does anyone have the factory setting's that may help set the red up many thanks again
    Genius:
  • 1,694 Answers
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Posted on Nov 27, 2007
  • Vista Electronics Nov 29, 2007
    Best guess without being there is a bad red CRT............T.
  • Vista Electronics Dec 09, 2007
    Probably a good idea to get the service manual for step -by
    step......possible minor yoke adjustment.....T.
Hi there ive got a toshiba 43vj13p very blue picture
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
Dec 21, 2009 | Toshiba 53H71 53 in. Rear Projection...
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Toshiba TP43h60 - Wondering what the dials are for
You are describing the MASTER SCREEN/ FOCUS CONTROL BLOCK---black with six controls--three are red, green and blue focus--the other three are screen controls--red, green and blue--- the screens are adjusted so with the color off you have normal brightness and a black and white picture--
They have nothing to do with any Convergence problem and unless they have been tampered with rarely need to be adjusted---
Let me know if this helps you AND IF YOU HAVE ANY QUESTIONS OR NEED ADVICE--LET ME KNOW.
I am here to help people.
SD TECH
Oct 09, 2009 | Toshiba TP43H60 43" Television
Pcture problem
Replace both STK392-110 convergence IC's with Toshiba or
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 43vj13p
if the people in the pic has red out lines or looks like theres two of them then sounds like convergence problems which you will need to replace the convergence chips which cost around £150 +vat. hope this helps
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
Red screen on 50" toshiba rear projection
red tub bad, you can adjust the red tub when you take the lower part of the front panel off and the plastic cover under the front screen
there will be 6 controls on the right hand side the three top are the brightness look for the one mark "R" and see if turning it down helps.
Dec 02, 2007 | Toshiba 50HX81 50" Rear Projection...
43H71 43 In Projector
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Nov 21, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
