table error; won't turn or load cd or play. removed all the cd's and there is no cd stuck any where....
(More)
table error; won't turn or load cd or play. removed all the cd's and there is no cd stuck any where. is it worth fixing?
After a cd is loaded into playing position the spindle motor does not start turning, hence the cd is...
(More)
After a cd is loaded into playing position the spindle motor does not start turning, hence the cd is not detected and the cd is unloaded. Than the next cd is loaded with the same result. This process repeats itself forever unless the powercord is disconnected from the mains. I replaced the optical pick-up assy A3328818A (base assy KSM-213BFN). This had no effect. Pls give me a possible cause and solution. Thank you in advace!
All functions ok except for one. When a cd is loaded into position the spindle motor does not start...
(More)
All functions ok except for one. When a cd is loaded into position the spindle motor does not start turning, hence the cd is not detected and the loadoperation starts again and keeps on going forever. I replaced the base assy (KSM-213BFN),OP with no result.
