Question about Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi wd 57731 wont power up
Hi I tried turning on my tv with the remote and nothing happened.I un plugged it and replugged it and the green timer light flickered for about 30 sec and stopped but the tv never came on.I tried remote and manualy.Nothing.Dont even get a power light.Do you think my bulb is burnt and needs to be replaced?If so when i remove it what will it look like that will show me its burnt out?Ive had my set for about 16 months.Thank so much Cory wong
  • 1 more comment
  • shameena Nov 26, 2007
    thank you
  • Anonymous Jun 02, 2008
    When I power up, the green timer lite flashes, I hear "white" noise but no picture, after a minute or so, it powers down. I've tried the reset, nothing changes, I unpluged for 15 min. no change. Any ideas ?
  • ccliles Aug 17, 2008
    my 62" Mitsubishi t.v, I have tried to reset it and unplug it but the grrren light flashes for about 30 seconds then it won't power on?
  • 1,284 Answers
There is a lamp cover on the back that only requires a few screws to remove. the lamp is behine there, you will need a standard screwdriver to remove the lamp and inspect it. If indeed the lamp is bad you will see it shattered and/or burned at the tip. The timer light flashing for 30 seconds is normal as the TV is going thorugh a boot up process. One word of advise, don't touch the glass part of the lamp pnly the case.
Posted on Nov 27, 2007
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
Replaced lamp but lamp light still blinks orange
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
Model WD-57731 LED Timer Light
You have a dm board problem could be the capacitors or you may need to change the entire board.
Sep 16, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Continuous green flashing light
ther are some bad capacitors on the dm board in this tv, but this model is not layman friendly, we usually send in the entire chassis to Mitsubishi for a rebuild this cost about $300 then there is the cost of service also, this job will probably cost around $5 or 600 dollars.
Jul 31, 2009 | Televison & Video
Mitsubishi wd 57731 1080p
see if there is dust inside blocking it.
Jan 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-57731 57" Projection HDTV Logo
229 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
