Question about Gateway FPD2275W LCD Monitor
Screen flickers badly at the resolution i want to use and no option to alter refresh rate - any ideas?
  • 81 Answers
Re: Screen flickers badly at the resolution i want to use...
He Dude...
Specify the monitor and the OS which u has I assume that u have the Samsung monitor coz this monitor having some problem….
Do one thing that is > right click on the desktop > go to properties > then click setting >
Click advanced > select adapter > check your adapter (display card) refresh rate > and click monitor tab and check your refresh rate… set to 60hz
Good Luck.
Posted on Nov 28, 2007
    Problem Solver:
  • 16 Answers
Try to boot on safe mode.then uninstall the display driver on the device manager.then switch to lower resolution, then boot on will detect the new driver.install it.if windows insist you to reboot dont do it.then right click on your desktop then properties then go to settings tab.on the settings tab click advance button.then go to monitor tab.then go to refresh rate.then switch it to 60Hz.then wallah.your desktop woill be ok.if same problem comes.try to changed your monitor.if same problem again.change your video card if it is not built in.
  • 57 Answers
I assume you're using windows XP or Vista ? The OS uses data from the monitor to tell it resolutions and refresh rates supported. If you get flicker and cannot alter the refresh rate, it is because the monitor will not supprt a fatsre refresh rate. Your only option, unfortunately, is to get a new monitor, or the cheaper option, use a different resolution.
Posted on Nov 27, 2007
0 characters
3 Points
Hi, my Acer S243HL doesn't work right
Reduce your resolution to see if the refresh rate can be accessed.
Jul 20, 2012 | Acer S243HL 24 inch Monitor
Get this flsh out of my monitor.
Hi there.
If the screen flickers, make sure the display settings in Windows match the native resolution and refresh rate for the monitor. You can find the native resolution of a flat panel display in the specifications, in the printed material or on the box that came with the monitor. Some common native resolutions are 800 x 600, 1024 x 768, 1920 x 1080, and 1680 x 1050.
The most common refresh rate for LCD monitors is 60 Hz. This normally cannot be changed for flat panel displays using Plug and Play settings. However, if you are using special video software to increase or decrease the refresh rate, change the refresh rate to match the default refresh rate specification of the monitor.
To change the screen resolution and refresh rate settings in Windows, do the following:
- In Windows XP
See my tip on setting up the optimum screen resolution for Windows XP here.
- In Windows Vista (Same for Windows 7)
1. Click Start, and then click Control Panel .
2. Find the Appearance and Personalization area, and click Adjust Screen Resolution .
3. Move the slider bar until the screen resolution matches the native resolution.
4. Click Advanced settings, and then click the Monitor tab.
5. Select the Screen refresh rate that matches the default rate for your monitor (if it is not already selected).
6. Click OK, and then click OK again.
If you cannot select the native resolution or the native resolution is unavailable, continue to the next step to update the drivers for the graphics adapter on the computer.
You can get the latest updated video drivers from the video hardware manufacturer's Web site. Here is a list showing some of the video hardware websites:
Check for NVIDIA video driver updates at NVIDIA Home Page.
Check for ATI/AMD video driver updates at ATI/AMD Home Page.
Check for Intel video support and downloads, Intel Downloads. (If you have an Intel mainboard and are using onboard graphics).
NOTE: If you are using onboard graphics with a mainboard that is not manufactured by Intel, just give me the name and model number of your mainboard and I can try and locate the graphics drivers for you.
After updating the video drivers, go back to Step 1 and try to change the screen resolution again.
Note: If you cannot select the native resolution after updating the video drivers, the graphics adapter in the computer might not support that resolution and may need to be upgraded.
If after changing the resolution and updating video drivers the flickering persists then check the video cable connections. Unplug the cable and inspect the cable for damage. If the cable is damaged, replace it with a new cable. Try to use cables less than 3 meters (10 feet) long.
Monitors are sensitive to magnetic fields so have a look at the environment around the monitor. Speakers, florescent lights, fans, cell phones, radios, and any other electrical device can cause flickering. Temporarily move electrical items away from the monitor to see if they is producing a field that causes the flicker.
If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, then this means that the graphics adapter hardware on the first computer is damaged or might need to be upgraded to use the monitor. On the bright side at least it's not your monitor.
If however the flicker remains then the problem lies within the hardware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchase and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
Oct 30, 2011 | Philips 190B6CB/27 19" LCD
I have a computer that i run dual montors on, both plug into the same video card, both monitors are crt's. my video card has 1 vga connector and 1 dvi connector. so i use a dvi to vga addaptor. now...
It is possible that you've got the resolution and vertical refresh rate set too high. CRTs tend to flicker if the vertical refresh rate is not set to about 72 to 75 Hz. If your screen resolution it set fairly high compared to what the monitor was designed to display it can overtax the video sweep circuitry in the monitor. If possible check the manufacturer's specs.
Often the video driver will let you specify different resolutions for primary and secondary monitor. If you can't find the manufacturer's specs it would be prudent to pick a less demanding resolution or vertical refresh rate for the secondary monitor.
Aug 10, 2011 | Computer Monitors
Hello, I have been using my asus vw222u monitor for a while now, connected to my dell dimension 4600 pc. I have been running the resolution at 1024x768, and been getting relatively clear pictures, but...
Your graphics card will not support that refresh rate @ 1680x1050. you may need to upgrade your graphics card.
Here is the best price/performance card for your machine. and will support upto 2048x1536 @ 85Hz
Hope this helps.
Apr 22, 2011 | ASUS VW222U 22 inch LCD Monitor
When i turn on my computer i get the message"NOT OPTIMUM MODE, RECOMMENDED MODE 1280x1024 60Hz" What is the meaning if this?
This is just your computer trying to give you the best resolution your monitor can handle. With the extent of modern technology being what it is, most devices will communicate information between themselves without a human being needed for most of it. This case is a perfect example. Many new monitors will "tell" the computer what their maximum resolution and refresh rate are, and the computer will automatically set your video card to use those settings. Resolution is the "1280x1024" part of the message, which refers to the number of pixels and size of area to be used on the monitor. Refresh rate is the "60Hz" part of the message, and isn't really important unless you see a flicker on your monitor or are getting into the advanced usage of a large, powerful monitor system.
The message you received was because of a miscommunication between the monitor and the computer. The monitor had no factory set value for its "Optimum Mode", so your computer was forced to ask you for input. The recommended mode should work just fine for you, so feel free to ignore that message unless it starts causing you problems, like an odd flicker in your screen or the screen not displaying your desktop properly.
Mar 06, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
Ive got the screen hooked up to my lap top everything looks great but when i play a movie the screen flickers
Screens will flicker during movies if the monitor settings or drivers are incorrect.
Check to make sure that the drivers for that model monitor are installed and up to date.
Go into control panel>display>settings>advanced>Monitor
and try changing the screen refresh rate (Hertz). You can also adjust the resolution from the settings screen as well.
Dec 21, 2009 | LG W2353V-PF 23' LCD Monitor
Trying to get rid of flickering on screen. now an
Flickering is caused by the incorrect refresh rate being used by your graphics card, go into the graphics settings by right clicking your desktop and choose the correct resolution and refresh rate dependant on the screen size and options. TRYING ALL THE OPTIONS DOES NOT CAUSE ANY DAMAGE TO YOUR PC OR MONITOR. Just pick the setup that suits you.
Oct 22, 2009 | ViewSonic VX2035WM LCD Monitor
I can not go past 1152 by 864 resolution, the screen will turn off and flicker also now it looks like video shown on the monitor is very high in contrast and sometimes the monitor will be on but no picture...
This means that you have reached the limitation of the graphics card of the PC that you have connected to it. You could try changing the Refresh rate of the card to see if you can get a higher resolution.
Oct 14, 2009 | Princeton Digital VL180 18.1 in. Flat...
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Kindly rate me if i was helpful.
Aug 25, 2009 | Hansol Computer Monitors
Screen flickers in 1680x1050 - samsung 2232BW plus
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
Dec 02, 2008 | Computer Monitors
Gateway FPD2275W LCD Monitor Logo
371 people viewed this question
Top Gateway Computer Monitors Experts
 Mike M
Mike M
olayoju victor
Are you a Gateway Computer Monitor Expert? Answer questions, earn points and help others
