Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Problem for Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Brushes don't turn
By pickleman846 on Aug 04, 2009
brushes don't turn
Solution #1
posted on Oct 24, 2009
Somewhat Helpful)
kellygal
Rank: Apprentice
Rating: 75%, 2 votes
I had the same problem and found a manual online. I never realized that there was a filter in the bottom of the machine. There are 2 red tabs, squeeze them together and pull ( I had to use a pair of pliers to pull). Note which is top and which is bottom tab. Clean the filter and reinsert. My brushes are now spinning!
Was this helpful?
Yes
No
Popular Solutions for Hoover F7425-900 SteamVac V2
Questions and Unsolved Problems for Hoover F7425-900 SteamVac V2
Do you recommend Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum?
Answer
Answer
this is a 6 brush model, the brushes do not rotate, the filter is clean and the switch is in the on... (More)
Answer
where do I put the detergent, I mean in which container?
Answer
steam vac turms on and suction/ brushes works but no water/ cleaner is coming out
Answer
i have the hover steamvac spinscrub widepath model f7410900. works great but now the scrub brushes... (More)
Answer
2nd time I used Bissell Pro Dry carpet cleaner ; plugged it in, turned it on, water pours out the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover F7425-900 SteamVac V2...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
