Question about Microsoft Windows XP Professional for PC
Win xp pro setup
During set up, the file "asms" on win xp sp2 couldn't be read. My CD is scratched up pretty bad. It wants to copy file from D:\ I386. It just won't read it off my disk! PLEASE HELP...........
  • 54 Answers
If you have the original xp disk with a cd key , then its perfectly legal for you to download a iso copy of xp , and install it, if not try and make a copy of the disk , and use that , or someone u know may have a friend with a xp disk , thats fine also aslong s you use the key that comes with your disk
Posted on Nov 26, 2007
Unable to do install of XP. during install process pc reports unable to copy various .dll's and other files from install disk. install disk is in perfect condition.
The message refers to the CD/DVD drive being unable to read from the CD itself. That could mean that either the disk is in bad condition and cannot be read (i.e. scratches, old disk, etc) OR that the drive has difficulty reading from the disk.
In the later case, it's the drive's fault and not the disk's (since you mention it's in perfect condition).
You could try cleaning up the drive but it's usually not worth it and since they're quite cheap, I would recommend getting a new DVD drive instead.
Hope that helps!
Mar 13, 2011 | AcerPower S285 (APS285UC3521) PC Desktop
Cannot install Windows XP Pro using the setup disk. I can delete the old partition and reformat the hard disk using NTFS, but when setup starts copying files it fails to copy a file (never the same file)...
It's possible that your disk-drive is "failing", and it's about to "die".
Buy a new disk-drive, connect it, and try to install to it.
Other possibilities:
* bad RAM in your computer is messing-up the file-copy operations, and the CD-reading operations
* dying motherboard is malfunctioning,
* scratched Windows CD-ROM media
* malfunctioning CD-reader device.
Oct 22, 2010 | Western Digital (WD1500ADFD) 150 GB Hard...
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Need file asms to complete installation
The problem is some files in your installation cd cannot be read anymore.
1. When the error appears try to redirect the wizzard to the directory of your CD ROM and locate the file.
2. If you have back up copy of your xp cd use it to replace the xp cd you are installing when the error appears.
3. If you have a copy of your xp installer on your hard disk re direct the wizzard to that directory.
Apr 27, 2009 | Microsoft Windows XP Professional
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Windows Xp Home edition
Its becoz your disk was having some error due to scratches so the drive cannot read from the discs so some files have to be skipped. I think you should reinstall from good disc without scratch! or damaged
Dec 08, 2007 | Microsoft Windows Xp Home Edition Sp2...
What are the steps to make win xp sp2 botable cd or floppy (which file i have to copy)
Are you saying you want to boot from the cd?  If so, insert the cd then restart you computer. It should boot into the windows setup.
Oct 12, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
278 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
