Where is the 5 amp fuse providing 12 power to the display on thetford fridges
The 5-amp fuse that provides 12V power to the display on your Thetford N180 fridge is most likely located in the main fuse box. Some Thetford fridges have a separate fuse specifically for the display, but others use the main fuse for power to the display and other components.
I would recommend checking the main fuse box again to make sure that the appropriate fuse is in place and that it is not blown. If it is in place and not blown, you can check the wiring leading to the display to ensure that there are no loose connections or damage to the wires.
If the fuse and wiring are fine, the issue may be with the display itself and it may need to be replaced. If you are not confident in troubleshooting the issue, it is recommended to seek assistance from a qualified technician.
