Question about Olympus EVOLT E-500 Digital Camera
E500 USB cable
I cannot plug into my new E500 camera the cable I have tried all cables supplied but none will plug in they look to be too small. Is there a\way of checking?
Thanks
  • jbloggz Nov 29, 2007
    It's the camera port it won't take the plug I'm now in contact with Olympus service and plan to take it to them. Thanks anyway.
    Genius:
  • 2,985 Answers
Plug it into where?
The camera or Computer.
The supplied cables[2] should match ports on the camera.
If they do not contact Olympus support
Posted on Nov 27, 2007
How to connect usb cable to w530
Your Sony DSC-W530 should have been supplied with a "dedicated" (special type) usb cable from new.
The USB cable plugs into the same jack as the A/V cable - they share the same port. This port is located on the r/hand side of the camera, under a small cover. Refer to item No.15 in diagram below.
The camera will install automatically on your pc when u connect it - allow a couple minutes for it to install. The location of your device can then be found under 'My Computuer', on your PC.
Nov 01, 2011 | Sony Cyber-Shot DSC-W530 Digital Camera
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    How can i opperate my camera because i constantly recieve the message "a usb device has exceeded the powe limits of its hub port"
    .I had the same problem and tried it on three different computers. I assumed that inline device on the transfer cable was a resister or something that went bad. I would purchase a new cable online but don't want to get the wrong one. Anyone know how to identify the end connector that goes to the camera? I am looking at: Mini B M/M 5 PIN
    Mar 05, 2011 | Konica Minolta DiMAGE E500 Digital Camera
    I have a Nikon L19 Coolpix camera which I bought at Carrefour in Cartaya, Spain. When I came to download my photo's from the camera to the computer I found the cable supplied in the box with the camera,...
    The USB cables supplied with digital cameras are almost all miniUSB to standard USB. The small connector on the cable fits into the camera, but it must be oriented a certain way. If you flip the small end the wrong direction, it won't fit. And sometimes the connection is tight. You can see on the small USB plug that it isn't perfectly symmetrical.
    Apr 22, 2010 | Nikon COOLPIX L19 Digital Camera
    Help finding a usb cable for the vivitar 8400.
    USB cables are standart cables and can be found everywhere especially stores which have electronic equipments and etc.So any USB cable can be used with most cameras.
    Mar 02, 2010 | Vivitar ViviCam 8400 Digital Camera
    Turns the computer off when plug USB into a computer
    did you try using the camera with a different data cable? there could be a peoblem with the data cable you are using
    Aug 16, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
    How to download picutures from D-540 olympus camera to computer
    Hi
    You will need the usb cable supplied with the camera.
    Follow these steps:
    1. Turn the camera off
    2. Plug the small end of the cable into your camera
    3. Plug the large end of the cable into a USB slot on your computer - there should be one on the front if it is a modern computer, otherwise you will have to find it one the back.
    4. Slide the power switch to the 'play' button
    5. Select 'PC on the list of options that shows up on your camera screen.
    Hope this helps, it's also in step 6 of the guide shown here (page two). The guide has a diagram to show you exactly where to plug the cable in.
    Good Luck!
    Philip
    Jul 12, 2008 | Computers & Internet
    Computer won't recognise camera to download images
    ** Problem Solved **
    I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
    So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
    Feb 13, 2008 | Cameras
    Is it necessary to load the battery (power supply) when the camera is connected to the computer via USB cable?
    Yes. Please use the battery or dedicated AC adapter. For transferring large size of images, using AC adapter is recommended.
    Sep 19, 2005 | Konica Minolta DiMAGE E500 Digital Camera
    Olympus EVOLT E-500 Digital Camera Logo
    Top Olympus Cameras Experts
    Steven Wander
    Steven Wander
    Jerry Greenberg
    Jerry Greenberg
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
