SOURCE: How do I download movies on my new Sony NWZ-S545
Manual for Sony NWZ-S545:
http://www.docs.sony.com/release/NWZS545_EN.pdf
Facts on supported media file formats on page 125-127 of the manual.
Windows Media Player 11, iTunes and even the Windows "drag and
drop method" can be used to transfer movies, having the format as mentioned in the manual.
The "Content Transfer Software" can be used to convert media into
appropriate size for the player. See all support on NWZS545 here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=NWZS545
For the software download select Drivers and Software on the left of
the support page. Next select your Operating System and go for
the download .
SOURCE: Sony 16g Walkman NWZ-S545,but system will not recongize it !
If you have XP SP3 installed , you might face this problem.
Go to the Device manage. Click on the update driver of the sony walkman device driver. When the dialog box appears select, choose install from a specific location, then click next.Then in the next part of the wizard, select don't search, i will choose the driver to install and click next. then choose from the portable driver, select USB root hub. Click next and finish. You are done and enjoy the data transfer and music.
SOURCE: its dead. there is no power at all, even when I
Hi konektor1,
Is it on hold? Check that first. If that is okay, and you still have it within the warranty period, get it checked for battery problems.
SOURCE: How can I change the background in SONY NWZ-S545
Hi snake 131,
I'm afraid you probably can't. I have one of these things, only one year older, but I have not yet found anything to do with changing appearances or color. I'm afraid it is stuck that way, but you can still check online at http://www.sony-asia.com/support/product/nwz-s545.
SOURCE: sony NWZ-S545 keeps blinking and won't turn on,
It might be the battery problem. You will need to change it.
You will find everything you need for your NWZ-S545 (operating guide, operating instructions and quick start guide here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=NWZS545
