Question about Rotel Audio Players & Recorders
Rotel RX-800 Hello everyone, I have a problem with my old Rotel RX-800. When I turn the volume up, I loose the sound on one of my speakers. It happens randomly, and has been tested on other speakers as well. Any idea? Thanks a lot in advance!
    Welcome Back:
    Visited the website for 2 consecutive days.
I have an RX 600 - which has just gone 'phut' - which is how I came today to find this website ! I once had your speaker problem but eventually tracked it down to a bad connection of the speaker cable into the rear of the Receiver. Plastic sheathing and dust was partly in the way. Strip off a bit more plastic to expose fresh bright wire, and remake secure tug-proof connection before you try anything else. Oh, and while you doing it, do the others as well !
Posted on Sep 11, 2008
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Volume dial doesn't work well anymore - when turning louder, sometimes turns volume lower or just stays at the same volume level
Some manufacturers allow you to set a max volume limit so you don't blow your ears off.  Check the users manual to see how to turn it off.
Also, have tech support install a new potentiometer for you.
Oct 25, 2009 | Rotel RX-975 Receiver
Rotel Receiver RX-950 AX popped and then quit
there would be life in the old girl it just depends how much you love her and how much you are willing to spend to get her fixed ?? some old rotels are still fetching good money so it might be worthwhile getting a quote
May 26, 2009 | Rotel RX-950AX Receiver
Right speaker jack not working
Why would it die from being in storage? Oxide or corrosion on contacts, volume potentiometer, Tape Monitor or other switch contacts.
Try manipulating all controls and switches throughout their ranges many times and see what happens.
Check the heaphone jack. If it works so does the right amplifier. While you're at it, insert the headphone jack multiple times to cycle its contacts, too.
May 18, 2009 | Rotel RMB-1095 Power Amplifier
Blown channel
You cannot fix the receiver unless you are a technician with the proper tools and circuit diagrams. I would think it worth the cost of repair though.
Good Luck
Jan 05, 2009 | Rotel RX-950AX Receiver
No Sound - Preceded by rapid input switching on its own
try a hardware reset based on instruction under
Oct 04, 2008 | Denon AVR-3805 Receiver
Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
625 people viewed this question
Top Rotel Audio Players & Recorders Experts
Stuart Slabber
Level 1 Expert
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
