We have a moutain aire motorhome with 2 dometic ac units in it. they seem to have packed it in the power comes on the lights are on but nothing happens they do not kick in, can these units be repaired and if so can you recomend someone in the langley Bc area
Are you sure they are getting hydro & 12 volts DC? Check all breakers & fuses. You should at least hear clicking at units when turned on. Not likely both would go like that. Does your unit have a switch to go from one to other or both? What brand & type of thermostat are you using?
New unit installation, 1800 BTU 220 volt. Getting voltage to both outside and inside units. Can't...
(More)
New unit installation, 1800 BTU 220 volt. Getting voltage to both outside and inside units. Can't get the inside unit to start.
about three years old worked great until now.system runs for about 15 min systems shut off...
(More)
about three years old worked great until now.system runs for about 15 min systems shut off completly,compressor amps high.line set leanth is about 60 ft,charged 2.3 lbs per foot any less and lines freeze.outdoor temps vary from top to the bottom of out door coil.
I bought 3 mini split systems from a company in NY and had them professional installed last summer. ...
(More)
I bought 3 mini split systems from a company in NY and had them professional installed last summer. When there was a prorblem with one of the unit I tried to use the warranty and no one responded. I contacted the Attorney General's office in NY and they tried to contact the company to no avail. I now have a problen with two of the units after having spent over $5000. One unit has a flashing error code of "E2" and will not come on. The other unit, the indoor unti will come on but not the outdoor unit. This happened after a power surge. Does anyone know what this erro code means and how to repair it?
LBJ
