Question about Konica Minolta DiALTA Di200 Copier
Konica 7020 fault F28
Fault F28
  • 19 Answers
F-28 codes deal with a corona unit arching.
if its a f-28-1 its the charge corona on the drum unit. more than likely its a f-28-3 though which is a seperation corona arch. these models were notorious for the insulating material that transfers voltage from the machine, to the door then back to the corona would eventually break down and start casuing arching.
what to look for, open the right side door and halfway down you will see a black peice of plastic sticking out that is attached by to screws. this needs to come off, but to get this off you will also need to remove the door opening bar. a total of 4 screws and you can have the black plastic peice in your hand. once off flip it over and open the back cover up. you will see 2 grey peicesof insulating material, one will be burnt the other will be fine. from here on it is up to you as to how you fix it. using an insulating tape that is cut to the opeing is an appropiate fix but it must be able to withstand high voltages. put it all back together and it should work.
Posted on Apr 15, 2008
  • 153 Answers
Just fill it up with silicon put back on machine will fix the the problem i have millions of them
konica tech
Posted on Apr 09, 2009
    An user who is expert in 3 categories / brands.
  • Konica Minolta Master
  • 1,362 Answers
Check this link go to error codes/konica
Posted on Nov 27, 2007
My konica 7022 display on the screen f28-1 just to fix it tnx.
Visual check the Charging corona Unit rear & front block look for burned cousing F28-1, then replaced Charging corona U.
Feb 13, 2015 | Konica Office Equipment & Supplies
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
How i can adjust the position of the Touch Panel display konica 7020
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
Oct 06, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
It starts and then stops and then F28 flashes
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F28 code problem in konica 1216 model what does it mean?
generally a dampness problem in the transfer seperation coroner to reset fault, turn of machine hold down 2 and 5 and turn on release 2 and 5 key in P then 4 then 5 then P then 0 then 0 then the green copy buttton then turn off then on should warm up if faults again when you try to copy I think you will need a technician hope this helps :)
May 19, 2010 | Konica Minolta Office Equipment & Supplies
I have a Konica 7020 copier reading an error code F-36-2 how do i fix it
Fuser error. Needs to be reset by a technician in service mode after the fault is fixed
Jul 22, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7020 f34-4
need to rest code 25 mode dip switch 3-1 should be 0
hope that help
let me know if you need more help with access
Sep 01, 2008 | Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
1,381 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
