Question about Compaq Evo N610C Notebook
Battery Problem One day I'd started calibration my laptop battery from 68%, it fully charged and then it became shut off at 68%. It never down to below. after some days I'd calibrated again, this time i'd started from 91%. then it started charged from 91% and fully charged. and became shut down at 91% when running in DC power. But the battery is full charged. I've tried in many way to solve this. but I can't. Please anyone help me. Sorry for my English.
  • Anonymous Dec 24, 2007
    when i charge the battary it gives an ndicator that it is fully charged but it stops responding after 3 or 5 minutes
    Problem Solver:
  • 5 Answers
You should tae your battery to a mechanic it may be a capcitor problem or may be a cells problem which are present in battteries
Posted on Sep 25, 2009
  • 482 Answers
Take out the battery, let set for a few min. and put it back in, try it. If does not work you need a new battery
Posted on Nov 26, 2007
My Gateway laptop, NE56R1u, shuts down automatically when unplugged even though fully charged?
Dear Leslie,
I had the very same problem with a HP Pavillion DV4 laptop and the problem was inside the battery - one of its cells became defective and the charge did not last more than a few seconds - it also showed a 100% charged icon but the battery was depleted in seconds.
Before buying a brand new battery you could check with a friend that has a similar laptop if he/she can lend you his/her battery for a few minutes and check whether the laptop keeps on or not with that other battery. In the case it remains on, it is the battery for sure, and you will need to buy a replacement one. Check the link below, for one option.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
6cell Laptop Battery for Gateway NE56R41u NE56R42u NE56R43u Nv50A02U...
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
How to charge your laptop battery properly? During the the process of notebook...
How to charge your laptop battery properly? solarroll-laptop-solar-charger.jpg During the the process of notebook using, we need no to deliberately charge the laptop battery to 100% state or fully discharged laptop battery to automatic shutdown protecting. The correct way is that charge the battery in 20% state and stop charging in 98% . If the machine has the power calibration procedure, when the battery standard-by time significantly reduced. Then calibrate the battery in time to active the protection circuit performance.
For early notebook batteries (Ni-MH Ni-MH or Ni-Cd Ni-Cd), really need to fully charge and discharge in order to maintain good battery capacity. But for the lithium battery is not necessary even it may damage the battery.
In fact the lithium batteries has a little memory effect. The lithium battery materials is very sensitive to the conditions as temperature, the use of frequency and so on. The battery will be aging after used for some period time (standby time reduced). The natural wear and tear is an important reason, and inadequate maintenance is another important reason.
A well-designed lithium batteries have a very good protection circuit to prevent excessive charge and discharge.As over-charging and discharging of the Sony VGP-BPS8 battery will be the rapid reduction activity. Under the protection of protection circuit, the user fully charge and discharge the battery several times, in fact, impossible to achieve had "full" level.
Sometimes WINDOWS show that battery capacity is 20% or more, you can use 30 minutes. But after used 10 minutes or less the machine suddenly automatically shut down. The reason is that the battery has been aging, the battery protection circuit can not monitors the battery real capacity. In the normal battery depletion, the protection circuit original parameters have been unable to properly reflect the actual situation of the battery
So power calibration procedure is to correct the benchmark protection circuit parameters to accurately reflect the actual capacity . This correction process will often take two or three complete charge and discharge. As previously mentioned, fully charge and discharge will reduce the battery activity. It is not frequently used, usually once a month.
on Jan 18, 2010 | Computers & Internet
Gateway laptop shuts down instantly when unplugged but fully charged.
I have come across connection issues on the battery terminals. Make sure the brass contacts are not tarnished or bent. Have you tried another battery?
No power
Try disconnecting the power supply and start it on battery only.
After you see a screen display of some kind, the power supply can be reconnected.
If this does not work, then remove the battery and start the computer using the power supply only.
After the computer start up sequence is complete, the battery can be re-inserted into the computer.
If the computer continues to misbehave on later restarts, then follow the more rigorous BATTERY RECALIBRATION Procedure below.
1. Now, after the system is up and running with both the battery inside and the power supply connected, after taking note of the current settings so that they can be restored later, set the power plan to High Perfomance, set the computer to Never Sleep on Battery and on Power Supply, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition. This will discharge the battery and performs phase one of battery re-calibration.
2. Next, plug in the power supply, while leaving the battery in place and restart the computer. Allow the battery to fully recharge while leaving the power plan at High Performance and the Sleep to Never. This performs phase two of battery re-calibration.
3. Then, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition, again, now that it has a possibly better, fuller charge than in the previous charge/discharge cycle.
4. Again, restart the computer, connect the power supply and allow it to completely charge the battery.
5. Shut down the computer, disconnect the power supply.
6. Restart the computer and allow the computer to run until it shuts itself off due to a low battery condition again.
7. Now the battery has been recalibrated. Connect the power supply, restart/resume the computer and allow the battery to fully charge again. The Power Plan and Sleep Mode can be set back to their original settings at this time.
8. The above procedure should only need to be performed every six to twelve months to recalibrate the battery.
This condition sometimes happens to my HP Presario when I have left the power supply plugged into the computer with the battery in for several days or weeks at a time, without running on the battery alone for a while to discharge and recharge it a little bit.
HP recommends that when running your computer for more than two weeks from the power supply, the battery should be removed to slow the aging of the battery, which can cause the battery to lose capacity or fail prematurely.
May 23, 2011 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
The battery is fully charged and loses the charge within 15 minutes of being fully charged. Battery is 18 months old!!!!! Help
Simple fix turn on the puter on the logo screen press F10 to go into bios setup page scroll over to battery calibration on the tabs on top you will see HDD and Battery choose battery.
Now hit calibrate.
1- Recharge
2- Discharge
2- Recharge
Let the puter complete all of the sessions without interruptions.
That will calibrate your battery to charge correctly. thanks.
Nov 07, 2010 | HP Compaq Evo n610c Notebook
How many hours to charge a new acer 4738?, mine is too long to charge, is it natural if new?
A brand new battery has to be charged for 8 hours.For any battery related issue, a reset or calibration can be done.Just drain all the charge in the battery by using the laptop only on battery power( ie,with the Charger/Adaptor disconnected).After the comp shuts down due to no power,then charge the battery for 8-10 hours and then check if its fully getting charged or not
At times a BIOS update can fix battery related issues.
Oct 22, 2010 | Acer Aspire One PC Notebook
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources),----- OR --- You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
Battery won't charge
a car battery? how eactly do you do that?
May 22, 2009 | HP Hewlett Packard Pavilion DV9500T 17"...
Compaq Evo N610C Notebook Logo
186 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
