Question about Tascam Audio Players & Recorders
On a Tascam DP 03, can you plug in a external CD burner directly into the Tascam DP 03 to record your project directly to disc, rather than having to import it into a computer to burn?
SOURCE:
  • 158 Answers
SOURCE: Iomega CD-RW 52x24x52 External Burner wont burn
have you checked the web site for drivers update and which burning software are you using if you are using on board xp stop using this and got for nero burning if you are on xp sp1 and try and upgrade to xp sp2 or win 2000 sp4 and clean cd lense and try that if same resaults it's time to redo windows as you may have currupted dll files and change usb leads over if possable
Posted on Aug 13, 2007
  • 189 Answers
SOURCE: what kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Posted on Jul 24, 2008
  • 189 Answers
SOURCE: Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Posted on Nov 10, 2008
SOURCE: Tascam DP-02 and Adobe Audition
Is there a way to get backward tracking
Posted on Nov 25, 2008
SOURCE: having trouble transfering my wav files from
I had the same problem too but I figured it out. First you have to make sure your wav file is converted to (MONO) as opposed to Stereo, (which is the default channel setting). The best thing to do is to download a converter program, in my case I downloaded AVS Converter program which all I did was upload the wav file switch it to Mono 1.0 and that was that!! The Cons: for this program it costs money to download for your own keeping. I also suggest Audacity program my computer wont let me download it but a co-worker of mine has it and he said it's free to download.
Posted on May 26, 2010
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
My tascam dp-03 track 4 rec button is unresponsive and doesnt light up but it was just working yesterday. the volume slider still works.
Some time with dust or Humidity there is a contact issue with the switch and the circuit so you need to get some contact spray spray it and should start working well.
Apr 18, 2014 | Tascam DP-03 DP03 8-Track Digital...
It is no longer recording. What can I do to fix or reset this thing?
hi, i got the same problem and found a way to solve it. i used cd-rw´s and the tascam spit them out
with a -disc-error-. i formatted the discs with my cd-burner prog. each cd-rw takes about 15-20 min.
i use burn aware, but nero or any other prog should do the trick. have fun kelly
Oct 26, 2010 | Tascam CD-RW750 CD Recorder
Timing of Mastering and burning final copy to CD
I don't use my Tascam to create CDs for exactly the reasons you are asking about. I do a bounce mix to a couple of tracks and then export via usb to a PC for finalizing and CD creation there.
To answer your questions, you do always need to create a master first for each sermon on the DP-02 before you can burn it to a CD. You also have to finalize the CD to play it on other players.
Mastering as well occurs in real time, so it does take 60 minutes to create a master for a 60 minute recording.
As I don't burn from my Tascam, I didn't realize the burn time was so long though. I would have expected that to be faster for sure. I know my old 2488 MkI is supposed to burn at 4x and I believe the MkII burns at 8x. The DP-02 is newer than both and I would assume it would burn even faster.
Anyway, as I said you might wish to go the PC route. That way you can export the tracks without having to master them and burn them from the PC to CD at up to 40x (depending on the speed of your PC's burner).
Hope this helps.
bd.
Jan 06, 2009 | Tascam DP01 All-In-One Recording Package...
Cheers,
bd.
Nov 09, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD
Unfortunately it's pretty much impossible to get a recording to sound like anything produced commercially these days without using lots of compression. Your burned CD problems might be the result of a faulty burner on your DP01-FX/CD. I have a 2488 and I still export all my mastered songs as wav files and burn them onto disc using my PC just because of the flexibility on the PC and you can control settings better which can cause disc burning problems (not to mention that the burner is newer and faster on my PC).
If you don't want to work on a PC you could look into replacing the burner in your Tascam. It is similar to replacing a PC's burner and the either the Tascam site and/or the Tascam Forum should be able to provide you with the specs and a list of compatible CD burners.
To get the final product to sound louder you could invest in an external compressor (a good used one should run you less than $100). You'll have to use the DP01's send loops to route a bounce of the stereo mix out to the compressor and then route the result back into the DP01 inputs and record on a couple of free tracks.
Hope this helps.
Cheers
bd.
Oct 14, 2008 | Tascam DP01 All-In-One Recording Package...
What kind of driver does my tascam dp 01 cd take.
Good luck.
bd.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
DJ EQUIPMENT
Lot of possibilities.
The DP-01 is like a mixer with built-in recording capabilies. You could plug your tunrntables into your DP-01 inputs, assign the inputs to tracks(channels) on the DP-01, and then output those tracks to two channels on your mixer (which would be connected to your PA.
Alternatively, you could plug the outs from your mixer into the DP-01 either by routing individual channels from the mixer into the DP-01 inputs, or outputting the mix into a single track (or into two tracks in stereo on your DP-01). Just assign the DP-01 inputs as usual to the tracks you want to record onto.
Those are just a couple of basic ideas. You could also route a DP-01 track (or the whole mix) back out the DP-01 send loop and through some external processors and then back to tracks on your DP-01, or you could do this through the mixer and then record the final result on the DP-01.
Jun 28, 2008 | Tascam DP01 All-In-One Recording Package...
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
