Question about Epson RX620 All-In-One InkJet Photo Printer
Scanner will not work!
I get (epson scan: escndv.exe - application error)
the instruction at "0x100aae1" referenced memory at "0x00213000". the memory could not be "written".
click on ok to terminate the problem
click on cancel to debug the problem
I also get (epson scan: escndv.exe - application error)
The instruction at "0x7c9111de" referenced memory at "0xfbf4f9fb". the memory could not be "read".
click on ok to terminate the program.
I have already re-installed the software 3 times and Epson has been no help. Can you help me?
Re: scanner will not work! - Epson RX620 All-In-One InkJet Photo Printer Printers & Copiers
Who cares... !!!
Posted on Jul 10, 2008
  • 2,985 Answers
One more try - this way
Remove all previous installations using the the Epson uninstall feature9Go to start/Programs/Epson side menu - uninstall.
Do this to all Epson modules.
No go to Start/Run in the filed type -REGEDIT
IN Edit[on the top bar] cclick on 'find.' in the field type EPSON
delete all that comes up.
Restart the machine.
Make sure you are offline.
Disable the Antivirus software.
Making sure the Software CD it spotless clean put in the drawer and follow the prompts.
Come back with with results - goood or bad
Posted on Nov 27, 2007
0 characters
3 Points
Will not scan. Error C:\ProgramFilesEPSON\escndv\es006c is displayed. Shows also ESCNDV.Exe
Do a complete reinstall.
1. Click Start, go to Control Panel, click System.
2. Click Hardware > Device Manager (XP). Click Device Manager (Vista and 7)
3. Look for Imaging Devices, right click on your Epson scanner and click uninstall.
4. Disconnect the usb cable from the printer.
5. Go to Control Panel > Add/Remove Programs (XP) Control Panel > Programs > Programs and Features (Vista and 7)
6. Look for Epson Scan and click Change/Remove/Uninstall.
7. Restart your computer.
8. Download the SCANNER software from the Epson website. If you have the disc, you can also run it.
9. Connect the usb cable back to the printer and computer.
10. Try scanning.
If that does not resolve your issue, you might need to remove Epson Scan from the Registry and reinstall the software again.
Nov 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Escndv.exe has encountered a problem
the website below offers step by step instructions that will guide you to correct the problem.
Jul 08, 2009 | Epson Stylus CX4800 All-In-One InkJet...
I have escndv.exe error problem with 4490 scanner. I've reinstalled the drivers and it still comes up
The first thing to try is uninstall the Epson Scan. Via either the start
menu item if one exits or from the Control Panel Add/Remove Programs.
Reboot computer.
Install the latest driver from the epson web site -
Latest is 2.68A for WindowsXP, etc.
You should go ahead and download a fresh copy from the web, your copy may be
After the install, reboot.
If that does not solve the problem.
You got to go deeper.
Remove the Epson scan. (again).
Backup your registry.
Edit the registry and remove all references to the Epson Scan.
Remove the folders and entries for Epson Scan in \Windows\Twain_32\
Install Epson scan.
Good Luck!!
Jul 03, 2009 | Epson Perfection 4490 Photo Scanner...
Cannot Scan - Getting an Error
You almost certainly have a virus.. these problems are usually caused by 'rootkit' virus. .these are virus's that your standard virus S/W can't see..
Download 'Unhackme' (google it) and install it.. Unhackme will get the virus BEFORE Windows loads.. it needs to be trained.. so follow the simple instructions as it can't alwyas tell the difference between a legit file and a dud.. it will fix your problem and make your system go faster too!
Jun 03, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Escndv.exe problem connected with Epson scanner 4490 Photo
Go here: C:\Document
s and Settings\[username]\Application Data\EPSON\ESCNDV\ES0058
and delete any image files in that folder. The last folder might have a different number depending on your scanner. It should start working again.
If you can't see that folder - click on My Computer - in the menu click on Tools and select 'Folder options..." Click on tab 'View' and select 'Show hidden files and folders'
You should now be able to see 'Application Data' in Docs and Settings...
May 30, 2009 | Epson Perfection 4490 Photo Scanner...
I have an Epson Perfection 3590 Photo and when I tried to open it this appears:"escndv.exe has encountered a problem and needs to close. Sorry for the...etc." I have already downloaded the Epson Scan...
This file that cannot be found "DICElib.dll" is actually installed by the LaserSoft SilverFast driver that comes with both scanner models. This file gets placed in the Epson Scan folders during installation because the LaserSoft SilverFast Driver works in conjunction with the Epson Scan driver for communication to the scanner. The solution to this issue is to uninstall and re-install the LaserSoft SilverFast Driver and NOT the Epson Scan driver.
On the "Start Here" poster it says that you have to install the Epson scan driver first before installing the LaserSoft SilverFast. Other possible causes are that the file has become corrupt, has been moved or has been deleted.
If this will not work, please call epson technical support. They have troubleshooting steps for that type of issue that cannot be disclosed here.
Please let them know if you have any other scanners or digital cameras installed on your system. If so, provide the model and manufacturer.
Sherlyn C.
Apr 16, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Everytime scanner option is selected an error message pops up
I Had the same issue, worked on it for weeks, was told it was registry issue, I reinstalled the software, said it was hardware problem....THEN I FOUND THIS AND as simple as it seems, IT WORKED.
Please follow the instructions below to help resolve this.
  1. Go to My Computer, by right-clicking the Start button. Select Explore
  2. Double-click the C: drive, then navigate to the following folders or location on the hard drive: C:\Documents and Settings\%username%\Application Data\EPSON\ESCNDV\ES00XX (where XX is any numbers or letters)
  3. Look for a BMP file or any file in this location and delete this file OR FILES THAT ARE .BMP.
  4. , can be xxxxx.BMP ( where xxxxx is the name)
  1. %username% above stands for your PC username.
  2. The Application Data folder is hidden by default, to un-hide this folder do the following in your Windows Explorer window go to the Tools pull down menu and select Folder Options
    Click on the View tab, look for Hidden files and folders.
    Select Show hidden files and folders option
    Click OK.
    you should now be able to see the Application Data folder continue in to the folder path above.
    (You may have to follow the steps again to turn off the Show hidden files and folders feature. )
  3. Removal and reinstallation of Epson SCAN does not clear out this file.
Jan 15, 2009 | Epson Stylus CX4800 All-In-One InkJet...
EPSON ACULASER CX11NF Scanning problem
Your epson scan software is most likely corrupted or there is another application consuming the memory on your pc. Try uninstalling the software and reinstalling. If this does not fix the issue, then you have another application on your pc causing you issues.
The epson scanner will not appear in your scanners and cameras in the control panel, this is one of the known funnies with windows and most manufacturers know about it. the create their own interface which you can find through you program files under epson scan.
Gremlin 11
Nov 26, 2008 | Epson ACULASER CX11NF All-In-One Printer
Scan functionality problems.
I have a problem error 90 for Epson stylus CX6000 All-in-one Printer
Sep 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Epson RX620 All-In-One InkJet Photo Printer Logo
268 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
