Question about LG Shine KE970 Cellular Phone
Reception My phone doesnt get any reception at all. Ive tried Turning it off and taking out the SIM card. I have also taken into the 3 store and they gave me a new SIM card. It worked fine for a day and now has stopped working. Any suggestions?
  • Anonymous May 22, 2009
    I had no reception but i just did what you said now it's fine. Thank u so much, it worked !
This worked perfect thanks.
i had the same problem when disconneting my phone from the pc aswell. thanks again
Posted on May 12, 2009
Try going into settings...flight mode....then turn it on.....then turn if off.....that should reactivate the reception.
I had the same problem after unplugging the phone from my pc....
Posted on Nov 26, 2007
My service has worked fine for months and i had been using the 50 dollar a month unlimited prepaid plan. 2 weeks ago i changed my plan to the prepaid 30 a month 1500min/text plan instead to save a bit of...
Did you change phones? Sim cards? I am assuming you have the same phone, and they switched out the sim card (or maybe not?) when you changed plans.
Also, all 4G phones are also 3G and 2G phones, and they simply pick the best available. So if you lose 4G coverage, it will simply switch to the wider 3g network and when you're really remote, drop to 2G. This effects data speed primarily, there isn't any qualitative difference between them for voice and text.
It sounds like you might have something screwy with your sim card when the plan changed happened, I would call T-Mobile or visit a store and ask for a new sim card and be vocal about the poor reception after the plan change. Changing plans shouldn't normally effect reception, only changing phones/networks.
I myself experienced reception issues like yours, and the problem was a bad simcard. I'm sorry for the vague answers, but I think your best bet is to go to a T-Mobile store. They should replace the sim card free of charge.
Oct 20, 2012 | Nokia 1616 Blue T-mobile Cell Phone -...
My iphone was updated to OS 4.2 and now it shows "emergency calls only" in several languages and two numbers namely IMEI and ICCID. how do I go back to the former operating system?
It's nearly impossible to downgrade. 1) Move the phone to a better reception area 2) if that doesnt work, try opening the sim tray(with paperclip end) and making sure the sim card is in place and re-close 3) If nether of those work, connect to iTunes and wait up to 30 min and see if it re-activates. 4) If none of the above work, connect to itunes and restore from backup. *** if NONE of this works, take it to apple store, it must have a serious problem.
Good luck
Feb 24, 2011 | Apple iPhone Smartphone
Lg cu920 - when I'm on a phone call, often call will disconnect. Don't think I'm touching the unlock button
Touching the screen unlock button should not have any effect on the phone while you are talking. Try turning off the phone, remove the battery and sim card, wait 5 mins, then replace battery and sim and reboot. If the problem persisits, and you live in an area where you have strong reception- 3 bars of more- then you need to take back the phone for service either to your provider or an independent, depending on your warranty.
Jul 23, 2009 | LG Vu CU920 Cellular Phone
No reception on phone anywhere all of a sudden
contact your cell phone provider (att, sprint, verizon). your service may be shut off.
Jul 11, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
Samsung u900 limited service
Is the battery fully charged now???
Limited service, is when your not getting any reception, Samsungs usually always get low reception or no reception at all if the battery is low or dying... Remove the sim card, reinsert it into the handset, charge the phone and try again...
If it still doesnt work and the sim card does work in other handsets, its still covered under the Samsung warranty if its less than 12 months old.
May 14, 2009 | Samsung U900 Soul Cellular Phone
SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
May 08, 2009 | Nokia N70 Cellular Phone
I get an opening message: "SIM card registration failed" - what does this mean? then i can't receive nor send any msgs.
1, The sim card is turned off, if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
May 08, 2009 | Nokia 6300 Cellular Phone
Cannot make/recieve calls+Text (T-Mobile)
This happens to me aswell. I think its because the phone is stolen. When i try to make a call, theres a beeping sound and texts fail to send, although there is reception & the phone works perfectly.
You cant even call 999, which doesnt happen with other blocked phones, so i reckon the police must be trying to trace the calls.
I dont know if this helps but im trying to think of a solution aswell.
Oct 19, 2008 | LG Prada KE850 Cellular Phone
Samsung j600
your phone's internal antenna could need replacing but take it to the store and see what other issues they find and see if itcan be fix or replaced.
Jul 08, 2008 | Samsung SGH-E900 Cellular Phone
LG Shine KE970 Cellular Phone Logo
67 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
