Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
ELink, Groupwise 6, and RIM Intellisync won't sync calendar items
By Ranny - usenet poster
I recently purchased a RIM and Motient's eLink service. Before that, I was
using RIM and Earthlink's Blackberry service. The reason I moved to
Motient was that I couldn't get the calendar to sync. Now I'm having the
same problem with the eLink service. I am able to send/receive email
properly and can sync address book and task items, but the calendar
syncing does not work.
When you add a new calendar item to the handheld and then try to sync, it
says that the nnew item(s) will be added to Groupwise, but when it goes to
add it, it kicks back a message saying "Unable to complete translation"
and the calendar item never gets added to Groupwise.
The calendar will sync fine when you first install the RIM software
(Intellisync), but once you add a new calendar item to the handheld and
then sync, it won't work. Has anyone seen that "Unable to complete
translation" message? Anyone know of a fix to get the calendar syncing to
work properly?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated)
man1
Rank: Apprentice
Rating: 0%, 0 votes
If you are using a Blackberry 857, 900 or 957, you might want to try out our
GWmobile product.  GWmobile is actually written as a "native" GroupWise
client specifically for the BlackBerry device.  It doesn't suffer from the
complexities or inadequacies of IMAP or other transport translations.  This
means that the GWmobile BlackBerry behaves just like a standard client for
GroupWise.  It is always synchronized, including calendar items, selected
folders, sent items, read items, etc.
You can get more information from www.omni-ts.com
Regards,
Aldo Zanoni
Director of Customer Service, Omni Technology Solutions
Was this helpful?
Yes
No
Solution #2
Not Rated)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
I ended up getting this to work. I archived a lot of older calendar items
(got it down from 8600+ to 1150 or so).
Motient and Puma Technologies were very unhelpful. After calling them
everyday for a week, they dropped the ball and said they didn't support
SP2 for Groupwise 6 (in regards to Intellisync)...even though they told me
in a previous discussion that pulling messages using IMAP would only work
if you had SP2 installed.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Duke
Rank: Apprentice
Rating: 0%, 0 votes
It's more likely that you had an item in the calendar that Intellisync
simply didn't like - archiving them got rid of the one in question.
I've synched many more items than that before to my RIM (and Treo, and
Kyocera . . .<G>), but when it fails it can almost always be tracked
down to a bad appointment, address book entry (cause I've had the same
error in the address book), etc.
Danita Zanr??
Novell Support Connection Sysop
Planning a GW6.5 Upgrade?  You need the GroupWise 6.5 Upgrade Guide
http://www.caledonia.net/updat e65.html
Was this helpful?
Yes
No
Solution #4
Not Rated)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
Not likely a Groupwise problem, since I just encountered this message
when syncing my Treo to Lotus Organizer.  The only unusual thing about
the calendar entry was (besides that it was created on the handheld)
that I had set an alarm in the handheld.  I don't recall this happening
before and haven't done any more troubleshooting on it, but it seems to
be Intellisync.
Lee.
Was this helpful?
Yes
No
Related Problems
In an attempt to synchronize my blackberry with my Outlook...
I can't find drivers for vista. Where can i find them??
I have an MP3 player that when you sync it using Windows...
being a newly owner of my pda i do have a lots of problem of...
Can you Help with these PDA problems?
can't install any application..gets...
Solve
can't install any application..gets an error its not a valid pocket pc application
turns on then turns of after...
Solve
My vivitar DVR 560G, for know reason at all just stopped working.The green led light will come on... (More)
htc model no dopad d810.cdma + gsm
Solve
htc model no dopad d810.cdma + gsm cdma is not working in india. in this model
i need a stylus for p565
Solve
Add Contact in Group
Solve
I have Blackbarry 8703e ,when i m add a new person in my addres book how i add the person in my... (More)
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 703
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(601) 918-0222
I will connect to your Computer and repair the...
(330) 502-6853
Instead of lugging your computer into a shop and...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
