FixYa.com
Tags:
Standard Televisions
Generic problem for all Standard Televisions
Set comes on with e.h.t for 4 sec,then goes off... (by 3 users)
posted by nnnn43 on Nov 26, 2007
Philips mod 32pw9544/75 standard T.v.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 30, 2008
This television is the Sharp 13k-M100 , similar symtoms, B+ reaches 169 then shutdown occurs. I have already replaced The horizontal output transistor and
the power supply regulator, also soldered a couple dry joints however problem remains.
Comment by terunky, posted on Dec 05, 2007
hello
I got the same problem with the fujitsu plasmavision 42 tv.
if i turn him on the led wil turn red and is flashing.
we thought of dust, but no.
what must i do?
help!
(and sorry for my bad inglish I am from holland)
Solution #1
posted on Nov 26, 2007
Not Rated (0)
Shuttle83
Rank:Wiz Wiz
Rating: 84%, 556 votes
The problem you described is a case of the shutdown circuit being activated. This is either due to an overcurrent or overvoltage condition within the circuirty of the TV set. This could be an open or shorted component in the High Voltage section of the TV, or an open or shorted component in the low voltage power supply section of the TV. In any case If I were troubleshooting this TV I would check the Horizontal out put transistor to see if it had shorted or opened at one of its junctions. I would also check to see if any of the voltage regulators had shorted or opened. I would also suggest that you check to see if you see any signs of burnt components (note the section).
If you do not have a background in Electronics, I would suggest that you take the TV to a qualified TV shop for repairs. This is because the work that needs to be done is not sinmple, and serious harm can result if you are not careful.
I wish you well on the repair of your TV.
Thank you,
Shuttle83
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE 31GT660 TV GE 25GT270 TV GE 19GT243 19" TV GE 27GT270 TV GE 27GT271 TV GE 27GT733 27" TV Panasonic CT-36SL13 32" TV
Can you Help with these Standard Televisions problems?
Aiwa TV-S2011 20"
MY CHANEL IS LOST
chanel 4 is lost Answer This...
Toshiba CF27G50 27" TV
Internal Speakers blown out.
On both internal speakers the... Answer This...
Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega Trinitron
The teletext display is... Answer This...
Sony KV-35S42 35" TV
wont turn on
only clicks and blinks Answer This...
tv wont turn on only clicks and...
tv wont turn on when i hit... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
