Cannot write cds at lower speed like 8x
Software writes at max speed reducing quality of audio files
only 8x writing works on my cd player
lesser speeds dont and higher speeds reduce the quality of playback
    Problem Solver:
  • 14 Answers
  1. Try to Use Nero or Easy CD creator software for better output.....
  2. Try burning Verbatim 16x DVD+R at 16x first and then burn another of the same type at 8x. And then compare the results. Most times, burning 16x-rated DVD+R/-R media at 12x or 8x will result in fewer PIEs/PIFs.
Whether 1x is better than 8x is another issue. Personally, I prefer 8x speed for most media I use these days (rated at between 4x to 16x but mostly 8x.)
Posted on Dec 09, 2007
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
Dec 03, 2011 | Sony (CRX230ED) CD-RW Burner
My pioneer cmx 3000 does not control speed correctly and produces draging audio out put
If your using burned CDs try burning them at lower speeds lower then 24x like 4x,8x,16x also try different brand disc. It's a common problem with poor quality discs and burn speeds higher then 24x
Nov 16, 2011 | Pioneer Audio Players & Recorders
yes, you can write it in 1x or even 42x if you want. The only thing that can happen is a chance of data loss but not quality. Also some older stereos could run into issues not just cuase of the write speed but cd incompatibilitiy. Audio CDs are nothing more than WAV files written on a CD and then a table of contents added as a CDFS file system.
Jun 29, 2011 | LG GH22NP21 DVD-Writer - Internal...
I have Mad Dog MD-16xDVD9-EXT. It says it can burn double layer dvd at 4X speed. I have dvds at 8X speed. How to burn at 8X speed with the existing burner? Need advice. Thanks
The bad news is most likely you will not be able to. If the specification for the device is a max 4x speed it most likely won't even be able to use the 8X media you have. You have to match the media to the device. All the specification data I find on the device indicates it writes double layer disk at max speed of 4X. It will write single layer disk at 8X.
Oct 09, 2010 | Mad Dog Multimedia Megastor DL...
Trying to make a cd in iTunes for my eclipse cd5444. Which CD write speed should I pick? iTunes defaults to maximum-and cd won't play. Should I pick a lower speed?
You must pick the speed that the CD allows. As long as you can play burnt cds in your car then any write speed will do. Try a cd in a different player if it doesn't work lowwer speed. If it does then your eclipse doesn't play burnt cd's. Also the format of Cd matters you might be burning an mp3 cd instead of a conventional cd and mp3 cds only work in players that support it.
Mar 23, 2010 | Eclipse 5442 CD Player
I want new laptop to write CDs - spec says DVD-ROM
Thats the spec for yout laptop, if you have the plug-on module then you can write on it.
Optical Storage
  • Type CD-RW / DVD-ROM combo - Plug-in module
  • CD / DVD read speed 24x (CD) / 8x (DVD)
  • CD / DVD write speed 16x
  • CD / DVD rewrite speed 10x
Good luck
Apr 27, 2009 | IBM ThinkPad T41 Notebook
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
