I had put a Sears 100-300 zoom (older model for my K1000) on my K100D and it sorta stuck when I took it off (I queried Sears about it being used and they said it would work just fine but no auto focus-dah).
It seems to take pictures fine but the view through the eye piece is dim. I can't tell if it is in focus because of it being so dim.
Any answers?
Thanks in advance. Jeff
Comments:
Nov 26, 2007
- Sorry, I should have been more elaborate. After I removed the Sears lens I put back on the Minolta 50mm that came in the kit.
After shooting more in daylight directly at a bright source, the picture are dark as well. So I would say your assessement of the coupling device is correct.
Are you aware of any service manuals for this model. I am disabled and don't drive much anymore, but I am an analog electronics tech and build detailed models as a hobby so I have no fear of taking anything apart...
-   I have the same problem with my Pentax K10. It isnt the lens on mine, it is the diaphragm release. The diaphragm release is up and should push down o open the diaphragm on the lens. I know what the problem is but not how to fix it. Any help on how to get into it would be greatly appreciated. -   jimmynotts
The lens you are talking about has either: 1)a faulty diaphragm mechanism ( lens stays closed at f 22 or f 16 when you attach it to the camera instead of opening fully as it should ) . or 2) the lens is fine but the diaphragm coupling mechanism inside mirror box ( on the left hand side if viewed from the front ) is not engaging the lens properly so that your lens stays fully closed ( F 22 /16 ) : because diaphragm stays fully closed image in viewfinder appears v. dark. Solution ? have a camera technician take a look but my guess is that the diaphragm needs cleaning and it should not cost you more than $ 80 bucks.
Comments:
Nov 26, 2007
- Here is a picture of a diaphragm mechanism from Canon auto focus lens , the principle is the same:
My Pentax istd AV dial has gone buggy. It jumps steps when turned or the stops go backward or...
(More)
My Pentax istd AV dial has gone buggy. It jumps steps when turned or the stops go backward or turning does nothing. Camera works normally in auto mode but manual adjustments via the AV dial are almost impossible...almost random.
Pictures a very overexposed. Inside I can shoot without a flash at 400 ISO and they come out right....
(More)
Pictures a very overexposed. Inside I can shoot without a flash at 400 ISO and they come out right. Outside they turn white.
Also the shutter speed won't register. I can set it at 125 or even 500 and it comes out at about 1/30 or 1/60 of a second. Lower shutter speeds are actually lower. This happened a day after I cleaned my sensor. Could that be the problems?
I have a problem similar. I haven't dropped mine, but when I take pics sometimes some come out with...
(More)
I have a problem similar. I haven't dropped mine, but when I take pics sometimes some come out with lines across the pictures and others don't. I've tried other memory cards but seem to be having the same issue no matter what cards I use.
i have had this camera for aprox 4 years. never had a problem. a few days ago, i was shooting as...
(More)
i have had this camera for aprox 4 years. never had a problem. a few days ago, i was shooting as usual. turned the camera off after reviewing a few of the shots. a few minutes later i turned the camera on again and it wouldnt power up. nothing in the lcd. replaced the batteries, but that didnt work either.
I have a pentax K100D and I bought a pentax AF-360 FGZ flash was trying it out on my camera and...
(More)
I have a pentax K100D and I bought a pentax AF-360 FGZ flash was trying it out on my camera and after I removed the external flash, the internal flash stop working.
