Question about GoVideo DVD-VCR Combo
Proluxe ce818 Hi!I have a proluxe ce818 that has the exactly same problem as the example. I can't hear the main character's voice, even though all back sound is fine. I have gone throgh menu but can not change. Some dvd's and cd's can hear without any problems. Let me know how I can fix it. Kind regards,Shohei
  • Andrew9196 Apr 13, 2008
    Same problem, The Background sound and Music is good but there is no audible speech,(the mouths move but no voice can be heard).
    The disc plays perfectly well on other players.
    Been right through all menu options a least 3 times and have found no solution.
    I have used different cables and tried both S Video and component connections.
  • callabrian Oct 19, 2008
    I received a freebie Proluxe CE818 DVD Player which is also suppressing the main characters voices. Suggestions on ways forward gratefully received.
I have this DVD player, and it has surround sound connectors, and seperately L/R connectors.
Whilst the L/R should mix-down the surround sounds, it doesn't appear to and only actually play the surround sound left and right.
My solution was to plug one of the RCA leads into the "Center" of the surround output, (can leave the other in the L or R slot)
you'll then get voice, out one speaker and ambient sounds out of the other.. It sucks, but that's why this things a freebie.. it's not well designed :P
Posted on May 28, 2010
  • 979 Answers
Using what type of decoding and hook up?
Posted on Nov 26, 2007
I need a handle and the hose for a Prolux AllVac. I have requested from Prolux, but do not get an answer
Write the CEO or Vice President of Prolux and see if you can get any help. Tell them what happened.
Jun 14, 2017 | Prolux Vacuums
Handle stays down
Doughpro DP1100 Dough Press - YouTube
? 1:27
www.youtube.com/watch?v=QM44NdPY3DQ
Oct 7, 2010 - Uploaded by ZescoVideos This is a how-to video for Doughpro's DP1100 Pizza DoughPress.
ProLuxe DP1100 PizzaPro Pizza Dough Press, Manual ...
www.missionrs.com/doughpro-dp1100-pizzapro-pizza-dough-press-man...
$3,074.60 - ‎In stock Product Description. Efficiently produce crusts that are equal to hand tossed in no time at all with this ProLuxe (formerly DoughPro) DP1100 PizzaPro Pizza ...
Oct 02, 2015 | DOUGHPRO/PROLUXE Dough-Pro DP-1100 - Pizza...
I DO NOT KNOW MY SECURITY PASSPHRASE
n most cases the default wireless settings are sufficient for normal home use.
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | 2wire 2700HG-B Router (2700HGB)
HOW TO CHANGE SSID
Nov 08, 2010 | 2wire (1000-000057-000) Modem
I downloaded Windows 7 and my wireless laptop won't connect to my 2wire. Where can I get new security key code or info get my laptop to work?
Hey pkkern,
Your default 10 digit security is located on the bottom of your router.
If you want to change it or for some reason your default key is no longer working we will have to get into the routers configuration homepage.
To access this open up your Internet browser and write in this address, (which is your routers address) 192.168.1.254.
If your routers homepage does NOT open up check to make sure you have no software firewalls
You will see a wireless network security section, use the following information to select a custom wep-key.
Change your wireless settings and use the following information if you want to change to a custom WEP key. 64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
Thanks for using fixya!
If you need information just comment in this thread and I will get back to you, don't forget to leave feedback!
Cheers,
Jul 24, 2010 | 2wire (1000-400108-001) Router
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
I have a Pioneer DV 585A DVD player that happily plays DVDs and the background sounds seems to be fine, but on some of the DVDs you can hear the voices of the characters speaking and then on another you...
Hi edwardm1,
If you are only hearing part of the audio from your DVD player, I would suggest you check your audio settings before seeking repairs.
Audio can be encoded to a DVD in several ways. If the audio on the disc is different than the settings on your DVD player, you may not hear all of the audio layers. For example, if your DVD is encoded in 5.1 Surround Sound, but your DVD player is set only to play basic Stereo, you may only hear portions of the audio.
Try accessing the menu on your DVD player, and look for the audio settings. If there is a higher setting available than is currently selected, try a higher audio setting. A higher setting should also be compatible with lower types of audio encoding.
If this does not improve your audio, or if you need help navigating your product menus, I would recommend giving Pioneer's toll-free support line a call at (800) 421-1404.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 13, 2008 | Televison & Video
DVD sound problem
Go into the setup menu into the audio options (use arrows on remote to go up and down menu and press left to enter the next menu to change options). By memory when I was running this just through a TV and not through a surround sound system, I had to turn off the addition speaker options in the audio menu. The one's like centre speaker etc have an small/large/off option. I had to turn these off so that all sound would come through the TV speaker only. That is about all I remember as I was trying to get this running for my aunt and I no longer have the DVD player.
Oct 04, 2007 | GoVideo DVD-VCR Combo
GoVideo DVD-VCR Combo Logo
299 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
