Question about IBM ThinkPad 380ED
IBM 380-ED Not Booting
After the RAM test it displays 161 & 163 Errors. I enter the Date/Time but it goes back to showing the same error.
  • 51 Answers
Check this link it will solve your problem
Posted on Nov 26, 2007
SOLVED! I had this problem with my Thinkpad 380D and FIXED IT.
No soldering, no expensive replacements, no special batteries needed.
Take a small screwdriver and open the panel on the underside of the computer, right above the big battery pack area. Inside you will see a watch battery sitting in a little round plastic cradle. The battery pops out easily with a small screwdriver. Buy a new battery at an electronics, radio, or jewelry store. You can bring the old one in to match it to a new one. Mine was a CR1220 and cost $5. Pop the new one into the plastic cradle, replace the panel, and turn your computer on. Now, after you reset the time, the computer should boot normally. This worked for a 380D. Don't know if it would work for other models, but 3880ED is probably similar.
Posted on May 15, 2008
How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
************************************************** i will also put in the link for the manual for additional assistance:
Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to set date and time
Set the date and time:
The current date and time are shown in the display when the machine is on and ready for use (Ready mode). The date and time will be printed on all faxes you send.
1. Press Menu.
2. Press Left Right Arrow to choose SET DATE & TIME and press Start/Enter.
3. Press Start/Enter when the display shows Date Format.
4. Press Left Right Arrow to select either Europe (day month year) or USA (month day year) and press Start/Enter.
5. Press Start/Enter when the display shows Date & Time.
6. Set the date and time. You can move the cursor by pressing Left Right Arrow.
7. Press Start/Enter when the date and time are correct.
1-AM 2-PM will display.
8. Press 1 or 2.
Dec 07, 2010 | HP 1050 Plain Paper Inkjet Fax
I have several 600's and they all have the same issue. They are giving 161 192 163 errors. I replaced the battery in them and then go to try and setup the time. However, instead of letting me set the...
161 = CMOS configuration lost (battery has died).
163 = CMOS error; Clock is not updating.
192 = System fan is faulty, not plugged into the system board or the system board itself is faulty.
Whe you replaced the RTC (real time clock/BIOS battery) did you make sure that the CPU fan was working?
If it is then go back into the BIOS and reset it to defaults. Save the changes and reboot, then go back into the BIOS and try to set the time and date.
Feb 22, 2010 | IBM ThinkPad 600 Notebook
Printing jerky, screen goes blank
BATCH or SETTLE before doing this for all data stored will be WIPED clean.
The flash memory needs to be reset there are RAM errors that need to be cleared out.
Unplug power Hold 1,5,9, and review down while holding it down someone can plug in the power cord it will take you to NOS Loader menu.
Choose option 6 or 8 Back to NOS Password 1947. Then choose option 6 service menu, then 1 hardware test, then 13 or 15 RAM TEST make sure it says RAM TEST. Then it will say this is self destructive it is fine hit enter when test is done it will take you back to the date and time mae sure you input it correctly then enter and it should then be fine.
Jul 09, 2009 | VeriFone (M19755014US1) Magnetic Card...
Thinkpad 380ED error 161 163
Replace CMOS battery and reset time and date. Turn the computer over. Loosen 1 screw on RAM and CMOS door and lift door away. CMOS battery is to the left of the RAM chip (if you have the extra RAM installed.) Using a very small flat screwdiver, gently insert it under the bottom edge of the battery itself, between the rdge of the battery and it's holder, and GENTLY pry up the bottom edge of the battery. It will easily pop out. DO NOT REMOVE THE BLACK PLASTIC CMOS BATTERY HOLDER ITSELF OR YOU WILL RUIN IT! Go to Batteries Plus or Radio Shack and perchase a CP1220 (3volt) battery. They are less than $4.00. Make sure that you have the new battery correct side up and insert it back into the holder by sliding it in from the bottom and gently push down and the new battery will pop back in. Re-start your machine and when the errors pop up hit "enter" and then enter the correct time and date. You should be good to go from there. Don't let anyone badmouth your 380ED. I have one that I used at trade shows for years and it still performs perfectly. It is built like a tank and won't run XP but Win98 is just fine on this rig. IBM (Lenovo) sure built them with the consumer in mind back then. Easy to add RAM and change CMOS battery, unlike my new ACER Aspire One, and my vintage AcerNote Lite that has to be completely dissambled to do either!
Apr 11, 2009 | IBM ThinkPad 380ED
IRe: IBM 600E
Hi, sorry I was out last night.
Errors 00161/00163/00173 mean you need to replace the CMOS/BIOS battery and update the time, date etc, like you did.. and Error 00301 means a keyboard error. Just press CtrlAltDel past this.. or try using an external PS-2 keyboard..
So, when you startup and then get to the errors, just press CtrlAltDel to restart, then tap F1 to enter the Advanced Settings and try to load Windows in Safe Mode, and let it do a Scan Disk.
It's possible that the machine won't be able to load any hardware drivers for the machine because the CMOS information might have been corrupted due to the flat battery, but try and boot into Safe Mode anyway and see how you get on.
This is a really old machine but still has driver and troubleshooting support at the Lenovo website, and it might be fun and interesting to resurrect..
Hardware Maintance Manual - June 1999: ThinkPad 600, 600E
On pages 109 and 115of the attached pdf file (actual pages 103 and 109), the Li-Ion batterypack part number should read 12P4064 replaces 02K7018.
c.gif Battery test utility diskette - ThinkPad 600/E/X
BIOS Update (Diskette) - ThinkPad 600
PCMCIA SelectaDock I/II driver for Windows 95/98 - ThinkPad 600, 770
c.gif Windows 98 installation supplement files - ThinkPad 600, 760, 765, 770
This is the Setup Guide for the thinkpad 600.
Of course, it may very well load Windows fine after a new battery and a scandisk and you'll find it has Windows 2000 on it, so maybe I'm jumping the gun with the Win98 stuff there, but let me kow how you get on..
Chris (ziraffa)
Oh by the way, if we are going to be using a different Solution thread this time, can you go back to the other page and rate it as Fixya! so that they can take it off the system? It saves the unrated pages filling up the servers..
Jan 17, 2009 | IBM ThinkPad 600E 2645 Notebook
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
if you have vista you could do a memory check in the boot options by resarting computer and key f10 boot options, then find memory check witch will display any errors with soloutions.
Dec 12, 2008 | Intel D102GGC2 Motherboard
Problem with saving time and date
After the warming up machines wants the Date and time.
first you press the stop button then enter 0101 followed by "enter" button. after one mints you machines display shows
"ready 100%"
if you are switch off the machines more than 7 hrs. again ask the date and time , then do the same steps above.
if you wants to enter the correct date and time pls. enter the month as first , then date , then year. suppose you want to enter today's date
like " 06012014"
May 23, 2008 | Samsung SCX 4521F All-In-One Laser Printer
My computer went back to older clock date as 1610
try starting your computer in safe mode and see if you can do anything productive there, like scanning for viruses or spyware. also check if you can do the following:
CTRL+ALT+DEL (open task manager)
goto Start>Run>Regedit (open registry editor)
goto Start>Control Panel>Display>Properties (change display settings)
right click on clock at tray and change the current time to correct settings
if you cannot do any of these activities, then your computer may probably been compromised by a virus or malware.
Jan 02, 2008 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
IBM ThinkPad 380ED Logo
174 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
