final spin cycle is not spinning fast enough, leaves clothing soaked at the end of cycle. final spin cycle is not spinning fast enough, leaves clothing soaked at the end of cycle.
AnonymousMar 14, 2014
clothes are still soaking wet after spin cycleclothes are still soaking wet after spin cycle
Probably the worst washing machine manual I have ever read!
Try this.
Put your wollens in the machine, set for cold water, Woollens Cycle and your 'Soak' detergent. It will agitate a bit, and as soon as it stops filling, turn it off.
After say 20 minutes. Then Move the dial to Spin, and pull the knob out. It _should_ pump out and spin.
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
I had that problem at one time with my old washer and what it ended up
being was the Washer Dog Agitators were broken and causing the it to
slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
Let me know if there is anything else I can do.
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
model: 110 4708 7600
serial: CST 471 0620
does not finish the drain cycle so it leaves the cloths soaking wet
