Question about iLO 3200 32 in. LCD Television
My TV is stuck on Digital TV function and I have cable only, how can I get this off.  I tried to get into the TV Menu and it will not let me in.  I have shut the TV off and unplugged it. Nothing it keeps going to Digital TV and say the channel is encrypted.
    Problem Solver:
  • 7 Answers
Since we figured it was looking for a digital input, we connected a HDMI cable from our digital cable box. TV is functional once again. We searched for 2 months with no luck on trying to fix this. It almost went out in the trash!!
Posted on Feb 19, 2008
Put in DVD and played ejected it can't get TV to come back on. lost remote has cox cable box tried input menu came up Tried turning tv off . Side panel doesn't seem to have an exit button.
Is there a button on the side panel marked dvd/tv or similar. Your tv may be stuck in DVD function and this button will toggle between them.
Aug 26, 2015 | Televison & Video
Quasar VV-1301 cant program for cable tv channels without remote, is there a way to autosearch the cable for channels so they are able to be selected
Ur tv have a manual Menu button on the front of the tv bazel frame?Yes used that manually Menu button pushes go into the tv menu to find select CABLE do autosearches by hand through a manually selected by functions buttons like channels buttons up and down as selections and menu button as enter to excicute functions.No try website like Remotes.com to buy the tv original remote to used.
Aug 18, 2011 | Quasar SP-3235 32" TV
I cant get my tv to get the regular cable channels. i just hooked it up to a new connection, it has no digital box, it runs straight through the cable. ive done the channel search and i dont know what else...
If your TV has a menu button, go into the menu and try setting the input of the TV to the jack that you connected your cable to. Sometimes the TV will not check all the inputs and just does the default one when you do the auto-tune search function to find the active channels. Also, check to see that your wall receptacle is actually hooked into your active cable TV line. You should have a splitter somewhere in the same line that your other TV is using. If not, that jack that you are hooking up your new TV to is probably not active.
Jan 01, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I just got cable hooked up and I'm trying to watch tv on an older Orion tv/vhs. When I go to menu options I can go to all of them except the channel set. I know the cable connection works because I hooked...
Try switching between Cable and TV on your menu. Or you can insert a VSH and when you eject it, you should be able to bring up menu and do a reset.
Make sure the cables into and out from are in the correct positions, as a cable signal go to the output will not work.
I'm sure you have checked the connections in and out but just needed to make sure !
Do you have a remote for the Orion, without the remote, you may not have the correct functions available to function properly.
Oct 10, 2009 | Televison & Video
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
I can't get rid of closed captioning!
Closed captioning can come trough 4 sources 3 of them access a digital file and display it to the screen. ALL must be set to off on each device:
Embeded in actual program video source--unlikely your problem.
TV decoder cotrolled by TV menu under "language"
Cable box--ditto for menu selection
DVD player or VHS tuner--Ditto for menu
Sep 17, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Can't record through A/V cable
make sure camera has this function first,Easy way to check is to see if top of camera has a record botton where play,ff,rew,stop are..Put camera in VTR mode then hok up cable to tv ..if no signal is comming thru,, check on camera menu for this function..LINE IN
Dec 07, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Oct 23, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
iLO 3200 32 in. LCD Television Logo
59 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
