Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Rear screen tv
Hi my general electric rear screen is about 4 years old...this morning it started to make loud cracking noises like a whip being was turned on at the wall but the actual tv was off...what is it please and is it worth fixing
  • 4,402 Answers
Re: rear screen tv
Flayback transformer or tv tube.
i would think it's worth reapir.
Posted on Dec 05, 2007
0 characters
3 Points
I was watching tv this morning and my set made a loud popping sound and the screen turned black. A red light appeared which read lamp and there was a burning smell. I unplugged the tv waited for a few...
The lamp is most likely needing replacement. Replaceing the lamp is a very easy proceedure on that model.I am pasting a pic where the lamp cover is located on rear cover. Remove the screw and the lamp is behind the lamp door.
Jun 08, 2011 | Mitsubishi WD-57734 57" HDTV
I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Hi We have no picture and it is making like a zapping noise at rear of tv like electric zapping ta
Hi you probly have a high voltage parts crack /sometime its the high voltage from the fly back
to the yoke plug or its cracked device like the screen and focus adjustement module.
dont leave it pluged in the wall, unplug it could make dammage to other parts
hope that help you
Mar 17, 2010 | Projection Televisions
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
Loud buzzing noise
sounds like a color wheel problem, I can send you a DIY File with pictures if you wish. Contact me at techman32K@ Good Luck!!
Sep 05, 2009 | Samsung HCM5525W 55" Rear Projection...
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Sharp 65dr650 rear projection tv makes loud nois while its on
Looks like we all got screwed with this TV. Mine just started after 2 years and now it's getting louder. I think I rather call my lawyer than Tech. This product is NOT build properly and someone should let the company know about it.
Jan 04, 2008 | Sharp 65DR650 65" Rear Projection...
MISTUBISHI VS-50501A - top 3/4 of screen displays ok, rest does not
Check the vertcle yoke pins for solder cracks. Check verticle output circuitry resistors and transistors. And also check for Coolant leaks from the CRTs this happens alot. Check capacitors for any signs of sweeling or heat as well.
Sep 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Loud electrical sound in rear of set(tv)
Sounds like the High voltage is leaking out and arching somewhere. Have a look in the back and see where it is BUT be CAREFULL!! This is enough voltage to cause serioud harm to you. If you have no TV repair experience, this is not the repair to start experiementing with. Play it safe and call out a pro to assist you. Good Luck.
Mar 31, 2007 | Zenith R40W46 40" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
