Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
How to fix Bissell Proheat losing prime after using spray for a short amount of time?
When I try to use the spray on my Bissell Proheat 7901, it quickly loses its prime and it will not spray afterwards. I just replaced the belt going to the pump and I tried priming it again, just for it to quickly lose prime again. Is air getting in somewhere? The gasket does not look bad on the bottom of the tank. possible leak in hose EDIT: I tried a "bucket" test to where the hose going to the SmartMix piston was put inside a bucket of water and it seemed like the pump was ok as it provided a constant stream of water. Would that leave it to the tank being warped and allowing air in?
3 Suggested Answers
SOURCE:
  • 33 Answers
SOURCE: losing prime on the pump
When the pump loses prime, you just turn of the unit, turn it back on and wait about a minute before pulling the trigger. The pump establishes prime when you first turn it on, but you need to wait long enough to let it get all the air out.
Posted on Jan 24, 2010
BissellCSR
  • 276 Answers
SOURCE: bissell will spray water when set to water rinse,
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve your issue, contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Posted on Sep 27, 2010
My bissell proheat shampoo machine won,t spray solution from the hand wand
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Aug 18, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Can any one send me a diagram of the internal water and soap connection for A Bissell proheat carpet cleaner Model #7901-1. i imagine pump also needs to be primed, which port do I use to do this. Thank you...
Click here for the manual - We think this will guide you,
As for the pump / port to be primed -
For Prime and loss of prime please click HERE -
From what Bissell says you must prime both - please read page 7 especially.
This should get you good to go.
Gary
Apr 10, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water does spray out when using floor bissel proheat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Mar 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell7901 is spraying water out by the wheels
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101 sfdgd
Bissell Proheat 7901 has continual leakage from
heatman101
456wet
Jan 20, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell 7901 runs for a short period then cuts off.
heatman101
9
Sep 26, 2009 | Bissell 7901-P ProHeat Upright Vacuum
Bissell Proheat 7901-R not doing anything--ready to scream!
heatman101
ewtywe
Mar 12, 2009 | Bissell 7901-R Clearview Proheat Plus...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
202 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
