Question about ASUS (M2NGREEN) Motherboard
DISPLAY Problem no display
  • 2,351 Answers
Re: DISPLAY Problem
Your video is integrated into the board. First check that the problem is not your monitor by hooking up another. Borrowing one if possible. Double check the video cable is connected securely at both ends, monitor & at the board. Your board does not support APG but you do have a PCIE slot. As a last choice you'll have to try a PCIE video card. If you finally do get video with a PCIE you'll need to enter your bios and change the video settings to PCIE. Your board is warranted for three years. You can call Asus IL eastern time US at. 1-812-282-2787, listen to the automated options this will connect you with tech support. Write down the boards S/N typed on a white sticker on the serial port. Tech will want this.
These things happen, hang in there!
Please vote...
Posted on Jan 28, 2008
0 characters
3 Points
Motherbord run but not dishplay
CAN you tell me the what is the display problem
Apr 11, 2011 | Intel Motherboard
How can i know which display driver should i download for my pc?
1) Looking at just the desktop screen, Right-click on an empty area.
(Minimize all windows that are open, or close the windows)
2) Left-click on Properties at the bottom of the list.
You will now be looking at a small window named > Display Properties
3) Left-click on the Settings tab
4) Look at the heading > Display, in the middle of the Display Properties window.
That is the name of your display, (Graphics) adapter.
The display driver should match that display adapter.
Have further questions regarding this, or need help, post in a Comment.
Nov 21, 2010 | Intel Motherboard
VGA problem
if your motherboard is not showing display -- Don't worry--
just buy a VGA display card from any computer hardware store,
it should not cost you more than Rs.500.
plug it into any of the PCI slots .
connect yout display connecter of your monitor now to this output instead of the default motherboard output..
you should get a display.
IF YOU WANT A BETTER DISPLAY by an AGP accelerated graphics display card.. this is costlier,
plug it in your AGP slot, this is different one than the PCI slot,
you will get a better display and computer will run faster , cos this will free up your RAM space.
Aug 22, 2010 | ASUS P5VD2-VM SE/BULK Motherboard
Intel desk top board no display
- remove all pci card
- check ram ( scrub with rubber eraser and broom ram slot with small brush, or your can troubleshut with new ram )
if still no display
- troubleshut with display card ( New display card )
if still no display
- troubleshut power supply with new power supply or any power supply is still good in condition( working power supply )
if display still not appear and your was do all tip above finally
you must troubleshut your motherboard with all your hardware. but your must use motherboard supported all your hardware.
Jun 10, 2010 | Intel D845GVSR Motherboard
My system display is not coming it does not display anthing
Try replace the Memory Module (RAM) with new ones, that's should fix the problems.
Feb 22, 2010 | Intel D915GAG Socket 775 Motherboard -...
Display is fading
Check the batteries first before trying to tinker with the display. Also check for accumulation of fungus, if any, which can also cause the display to fade..............sodeep
Jul 21, 2009 | Motherboards
845 gvsr display related problem, geting pink display from board
the problem is not with the driver, the problem is with ur monitor signal cable.
if you wish to cross check just unistall the display driver and see u will see the same pink color
Jan 08, 2009 | Intel D845GVSR Motherboard
I want intel desktop D845 EPI/ D845 GVSR DISPLAY DRIVERS
I cannot find the exact brand of your display driver, here's a link which I think give you an idea of what display driver you need, and download that driver.
Nov 05, 2008 | Motherboards
Display on laptop
Have you tried plugging in an external monitor to see if the display is ok. I suspect you will find external display is perfect and only the LCD on the laptop is affected.
I have a laptop that the "tab" welds are not connecting properly on the lcd and 1/3 of the display is multiple lines or black. Pressing on the top of the lcd changes the colors on the display but does not fix the problem, I had to replace the lcd.
Mar 23, 2008 | Intel Motherboard
ASUS (M2NGREEN) Motherboard Logo
78 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
