Question about Philips Magnavox 52MF437S/37 52 in. LCD TV
TV will not Power Up / Blinking Green Light on Power Button
This phillips Magnavox 26D/32MD251id LCD TX with DVD player is one year old. It will not power up. I tried the manuals suggestion of unplugging it for sixty seconds, same problem.
No, Sound, No Picture, just black screen.
Please help me.
  • The Cob Apr 10, 2008
    I just bought the same tv today it worked for an hour...I closes it off and when i turned it back on, i looking at a black screen and a green blinking light......I am calling the company tomorrow
  • etpassgo Feb 08, 2009
    I bought a used HP LC3760N 37" HDTV LCD with the same problem, blinking green light, but will not power up. I was told by HP support most likely its the mainboard. I removed the rear cover and it appears the clicking noise comes from the mainboard in the back. I'm planning to replace the mainboard, hopefully it solves the problem. If not then I will take this tv to a repair shop. I did notice that some of the components are
    SHARP, i'm assuming its made by sharp, not sure.
    Problem Solver:
  • 4 Answers
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Feb 28, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Power green light Blinking, Will not power up.
Got this from Phillips:
Question My TV has no picture.
Answer Press the menu button on the remote. If the menu appears you are probably experiencing a signal or connection problem.
If you have a menu check the following:
  • Video inputs may be shared. If you have sound but no picture, check that audio and video inputs are going to same.
  • Check antenna connections at the bottom of the TV to see if they are properly connected to the TV.
  • Possible broadcast station trouble. Try another channel.
  • Adjust the contrast and brightness settings. Try another auto picture setting.
  • Check the Closed Captions control. Some TEXT modes could block the screen.
  • Check if you selected the correct AV source. (For LCD TV with built-in DVD player, the correct DVD source is AV1.)
If you have been watching the set and you loose picture:
Your TV has a protective mode in case there is too much heat build-up. Check the clearance around the vents of the device to be certain there are no blocking walls or cabinets which would limit the air flow.
Is it installed in a TV cabinet? These models produce a lot more heat than you think. So the last suggestion is a likely culprit.
One other possibility. Some models have these, some don't but look for a small "red reset button" recessed some where in the back of the set near the power cord. It is a built in circuit breaker.
Nov 26, 2007 | Televison & Video
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like, to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
Phillips LCD TV,green power light changes to red blinking light when power button is pic and no sound.
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Please post back what you find
Dec 18, 2009 | Televison & Video
Red light power blinking
power supply problem this can be done by a professional tv repair
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Dvd freezes
If less than a year old, this TV is likely under warranty but should have been taken back immediately to address the issue. I suggest contacting the vendor or manufacturer.
Jan 04, 2018 | Philips Magnavox 27MS343S 27" TV
Phillip tv
Probably bad inverter board. It has a short in inverter board and as soon as it powers up it detects the excessive current draw and shuts the set back off. Open it up, unplug the power supply connections to the inverter board then try to turn it on, if you get a green light then the inverter is bad. Try E-bay for replacement board.
Apr 16, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Phillips/Magnavox 26MD255V
manual eject button is on side were you load the disc
Nov 09, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Philips Magnavox 52MF437S/37 52 in. LCD TV Logo
505 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
