Question about Konica Minolta magicolor 2300DL Laser Printer
Cartridge Removal 2300DL QMS Minolta
I need to remove all the cartridges from my 2300DL QMS manually eventhough they are almost full. Something is wrong becasue the magenta color is leaking and the fuser is not heating up enough to blend it in a fuse with other colors. I think I just need to clean it with compressed air, but don't know how to remove the cartridges if they are not empty. Any suggestions?
  • Anonymous Feb 01, 2009
    Mine always stops on cyan and will not turn to allow me to change rest of cartridges
Magicolor 2300 DL procedures
a)From the display, select the menu “Engine”.
b)Select “Replace Toner”.
c) Select each color toner cartridge from this
menu to remove it.
Posted on Dec 20, 2007
How to change cartrdridge
To replace the cartridge on the Minolta Magicolor 2300DL open the side panel and remove the cartridge. If the cartridge to be replaced is not visible then look for a small hole on the upper left side of the cartridges. While pushing a small screwdriver into the hole and pushing it in turn the cartridges with you fingers until the cartridge to be replaced is visible and then remove it and replace it with the new one. Once you have the cartridge installed close the side panel. The printer will start to reconfigure the new cartridge. Once its done the green light will come on and your ready to resume printing.
Frank O'Connor
Feb 21, 2013 | Konica Minolta magicolor 2300DL Laser...
How do I change the ink cartridge?
Hello.
This printer is a laser jet printer - so you will be changing the multiple toner cartridges, not ink cartridges.
Page 56 starts the steps on how to replace the toner cartridges.
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2300dl/eg_user.pdf
The front of the printer opens to the right and exposes the toner cartridges for removal.
May 04, 2010 | Konica Minolta magicolor 2300DL Laser...
Our 2300DL is leaving streaks when printing
Out of one or more toners. If you have removed and replaced a cartridge in error the % remaining is reset to 100%. Try to determine which color is missing in your print out (usually black), and then follow menu instructions to replace that cartridge. The ends are color coded so be sure you change the correct one. This will insure the remaining cartridges % remaining is correct.
Jan 13, 2010 | Konica Minolta magicolor 2300DL Laser...
How do you replace the black toner cartridge
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta QMS 2300dl
fix your cartridge again to its position .
also check there is not any paper jam.
open back side case of printer then check thee is not any papaper jam.
Nov 01, 2008 | Konica Minolta magicolor 2300DL Laser...
How do you change the drum cartridge ?on a 2300 qms minolta printer
Replacement of the OPC Drum Cartridge
1. Open the Front Door.
2. Remove the Waste Toner Bottle.
3. Lower the unlock lever and remove the Drum
Cartridge.
4. Reinstall the new Drum Cartridge
5. Pull the protective sheet of the Drum Cartridge to
the front and remove it.
6. Raise the unlock lever.
Jun 09, 2008 | Minolta magicolor 2300W Laser Printer
Cant replace a toner cartridge
It's done via the printers internal menu system:
On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta QMS magicolor 2300dl
It sits on the left hand side behind the HVPS, if you want the manual, update with your e mail address and i'll forward it (it's 4.17mb)
May 18, 2008 | Konica Minolta magicolor 2300DL Laser...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
416 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
