Question about GE Kitchen Ranges
Need outer glass door for GE JKP26GOP1BG or something to replace the part. can't find it anywhere. I am told parts no longer exist. is there a way to cut something to size and fit to it to work?
They have door parts this size but the holes for teh handles are in the wrong place. wondering if there was a way to get something to replace it.
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Posted on Dec 05, 2006
SOURCE: 2033 kia sedona sliding outer door handle
take inside door pannel of,gently remove plastic sheet,and you will see door handle,un clipdoor lever and nuts,
Posted on Jul 18, 2008
vitg55
  • 78 Answers
SOURCE: replacement part needed for GE Spacemaker Micro. (JVM1631BB004)
Appliance online store:
http://www.repairclinic.com/
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 01, 2008
SOURCE: 2006 Ford Fusion inside door handle stopped working
The plastic door handle is broken.
You will need to get a replacement door handle.
Go to http://www.flickr.com/photos/gtppilot/sets...57607539089979/
This should help. It is a set of photographs and instructions to do the job of replacing the handle.
Good luck.
Rgrdrake
Posted on Apr 10, 2009
breddi2
  • 126 Answers
SOURCE: the mesh screen on the inside door has a hole in it..
would suggest replacing door for safety purposes only," it could be fine as far as resisting waves",but never sure for how long or if it realy is. An old saying makes sense," Better safe than sorry".
Posted on Apr 26, 2009
Help need replace glass panel in pvc
This door is radius and would be difficult to replace. Repair clinic claims the part is due in at the end of this month, I wish you luck on your search. I have not seen someone make this correctly as the metal supports at the bottom are attached to the glass and the stainless steel outer panel is just a panel stuck to glass.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Feb 05, 2014 | Jenn-Air Microwave Ovens
The inside glass (between the inner and outer glass of the door) of the upper oven door of my GE JT952-30 shattered during a baking cycle. I need the replacement part number and a possible source.
Hello would need the entire model number as you can see by this link there are 32 models of that oven http://www.searspartsdirect.com/partsdirect/part-model/JT952?searchModPar=JT952&pathTaken=modelSearch&prst=0&shdMod=JT952
you can either message me back and I will then pick which is your unit then you would go under door schematic and it would bring up the diagram for your unit which when you clicked on door it would being you to this blown up view of the door this is an example http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Wall-oven-Parts/Model-JT952BF7BB/0432/0125300/G0510389/00005?blt=06&prst=&shdMod= and if you scrolled down to like on this schematic has the outer door glass shown as number 140 in the diagram and then underneath that it would give the part number such as it does for this one being
PART NUMBER: WB57T10259 if you have any further questions or would like me to look your model up further please message me back with the complete model number Thanks Rick
Jun 28, 2011 | GE Profile JT952 Electric Double Oven
After cleaning the inside of glass door is still dirty? What should I use to clean it?
you need to split the inner and outer door panels, then remove the inner glass pane from between the 2 sections then carefully replace all parts especially if its a self- clean oven type
Mar 05, 2011 | GE Kitchen Ranges
I need to replace the outer black glass oven door panel on our Kenmore stove, has broken and the part is no longer available. Size of panel is approxiamtely 20" X 30", needs to be tempered. I can have...
If anyone can locate this part I would bet on appliance parts pros:
1-877-477-7278 http://www.appliancepartspros.com/part_details.aspx?part_id=2035287
This door glass was originally made by GE.
You can also try the repair clinic:
800-269-2609
http://www.repairclinic.com/Appliance-Parts?s=t-WB57K5121-%3d%3d
These 2 sources will probably be your best bet. I know it says they are not stocked.
As I said GE made this door originially. You can call their parts line at :
Parts:
Call: 800-626-2002 Start with the call to GE parts first using your WB57K5121 part number. Fingers crossed but as a service tech this is exactly what I would do if I were faced with your situation. Wish you the best and would appreciate any feedback on your search results. Thanks for choosing FixYa. Kelly
Aug 19, 2010 | Ovens
Tappan oven door seal replacement
You will have to google the parts may be very hard to find but you never know what comes up .
Mar 16, 2017 | Tappan TEF242 Electric Kitchen Range
Replacing outer glass of oven door
This is glass because glass does not burn, does not melt at oven temperatures, and is a pretty good insulator. Also allows the cook to watch the cake rise.
I would not replace with anything but factor glass. Too dangerous, even regular glass is not properly treated to be safe in this environment.
The cash for clunkers gets extended to appliances soon, perhaps this makes a new one more affordable?
Aug 24, 2009 | GE Profile Spectra JGBP85 Gas Kitchen...
Can't replace outer glass on oven door.
Go to (www.searspartsdirect.com). Enter your model number and select (door) under (browse subcomponents) You can view the door assembly parts. Hope this helps
Mar 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven door
Contact your nearest appliance store. Most have GE parts in stock. This may be more available than you think. I have seen someone take tempered glass and literally glue it with special heat resistant glue and it looked really pretty nice. The edges were beveled and not sharp. This of course is a last resort.
Feb 05, 2009 | GE Ovens
I need to replace my outer glass door of my oven its an indesit i have all the parts but just can't get the old piece of glass off any ideas? please
You may have to disassemble the door to get to it. Are you sure this is not a double paned glass and it is 2 pieces of glass in one assembly?
Jan 29, 2009 | GE ZSC2001FSS Advantium Electric Single...
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
