SOURCE: cannot connect to internet Model WRT54GS
Hi vmveal, try this. (Do not remove the RJ45 cables from modem to router, router to PC). Power off the PC.
Unplug the DSL or cable modems power cord. Also unplug the routers power cord. There is a small reset button on the back side of both, (Modem & Router). Take a pen & push the reset button in for 10 seconds. Modem first & than router second.
Re-connect the modems power cord, than re-connect the routers power cord. Once both have powered up turn on your PC.
If this still fails to give you internet access you can call linksys or chat with linksys at this site: (See left side of link & bottom of page).
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859761879&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=6187941396B11
To talk with linksys tech, the number is in your manual.
Good luck vmveal!
Mike
SOURCE: I turn my PS3 on and the screen is always blank. I
I recommend you try to access Safe Mode again.
The way I understand it, your ps3 is supposed to turn off after the third beep as you keep holding the Power button. Then you start the sequence again, and this time you will get the double beep.
Of course, Safe mode is only available for PS3's with system software of 2.60 and higher, perhaps yours is older than that?
I hope that helps.
____________________________________
Sony PS3 Safe Mode
SOURCE: how can I channge event log if I can't enter set up with F2
if you want to get the event log and the error code
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
hope this helps
