Question about Motorola Mobility RAZR V3
Buttons don't work
Only button that works is on/off button. Any other key I press the back light doesn't light up. When I close it, I can receive calls by opening it, but I can't call anyone. Also, when I flip open my phone, the texting menu appears automatically.
  • 30 Answers
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Posted on Nov 26, 2007
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
Mercedes c class 2001 elegance, key fob not working everytime its pressed. I have had the batteries checked and they are still working fine, any advice as to what is causing this?
Most likely needs to be re matched to the car.
Two bits of info off the net for you
C CLASS (1993-1997), E CLASS (1995-1997), SLK (1996-)
1. Point the remote control at the receiver - this should be located in the driver's door handle or next to the boot lock button.
2. Press the lock/unlock button.
3. Within 30 seconds manually lock or unlock the vehicle using the passenger's door lock or the boot lock.
Alternative method
3. Within 30 seconds, switch the ignition ON.
Alternative method
3. Within 30 seconds, turn the ignition switch to position II.
1. Place key in ignition lock and turn to position 2 [all ignition lights on]
2: Turn key to off position and remove from ignition.
3. Within 10 seconds:
3a: press the Close [Lock] button and hold it down
3b: while the Close button is still depressed simultaneously press the Open [Unlock] button. Press and release the Open button 5 times [still holding the Close button down]
3c: Release both the Close and the Open buttons at the same time, and immediately push any of the two Open buttons once [i.e. either the Open doors or the Open Tailgate]
This information is for the resetting of a previously synchronised key to match the security system after batteries have been removed or replaced. This information does not work with new keys which it seems must be taken to a person with a key synchronisation device [or a super-ripoff-expensive MB dealer]
hope this helps
Aug 13, 2011 | 2002 Jaguar X-Type
My eee pc 901 doesn't have a working keyboard, someones fiddled with it and now normal keys don't work, but if i press the G key it brings up the goto line box, and all the other keys you'd...
It seems to be there is pressed button and should be released.
Try with the control keys like ( Ctrl, Alt, Shift, both right and left, and Fn key ).
Press these keys hardly ( not much ) to release them,
Please, Tell us your results.
Good Luck
May 16, 2011 | ASUS Eee PC 901 XP Notebook
Maint. req. light blinks 10 times after start up?
When a Honda Maint Req light blinks, but then stops, it is telling you to change your oil. If you don't change it, eventually, the maint req light will stay on. Here is how you reset the maint req light: 1) Turn they key to the II position
2) Turn the key to the off position, and push and hold in the odometer reset button
3) Turn they key back to the II position, while still holding the odometer button.
4) After about 10-15 seconds, the light should go off.
If that doesn't work, try it this way: p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Verdana}
With the igniition off, press and hold the odometer button, turn the key to the "on" position, but do not start the car. Keep the odometer button down until the oil light begins and ends flashing. Turn the key off, and then start car to see if it worked or not.
May 08, 2011 | 2005 Honda Element
Need remote control code for dish network along with how to instructions. I can't locate my manual for my Zenith
Try this...1) turn on your tv set manually.2) on you dish and hold the "TV" mode button next to the "SAT" button.when all of the other mode buttons light up, let the "TV" button should be flashing.3) Press the blank power button(The top red button in the top center of the remote).4) press the UP or DOWN button at the rate of about 1 per second until the tv turns off.4) When the tv turns the # key on the bottom right of the remote...this stores the code and you should be ready to go...please try this first..It should work.If the scan doesn't work...The only code for Orion is "694".I hope this was helpful....
Jun 15, 2010 | Zenith C32V37 32" TV
Key board will not respond. Mouse works fine.
Normal 0 Make sure the batteries are good then try the following.
Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Dec 07, 2009 | Computers & Internet
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Jan 20, 2009 | Brother HL-5240 Laser Printer
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Motorola Mobility RAZR V3 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
