Washing Machines Logo
F
Foo Mei Leng Posted on Nov 19, 2018
Siemens Siwamat 2085, the knob for adjusting the duration you want to wash the clothes is jam, may I know how to adjust it back ? Kindly advise, thank you.
5 Related Answers
Anonymous
  • 209 Answers
  • Posted on Oct 10, 2007
SOURCE: Washing machine not spinning
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
Anonymous
  • 8197 Answers
  • Posted on Dec 16, 2008
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Anonymous
  • 13 Answers
  • Posted on Jul 17, 2009
SOURCE: Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Anonymous
  • 180 Answers
  • Posted on Nov 07, 2009
SOURCE: Hello! Our Bosch-Siemens clothes washing machine
Make sure you use high efficiency detergent.  The front load machines take a special kind of detergent to make them run smoothly.  Check your drain hose for clogs, and clean the pump again.  If none of these fix the problem, you will probably need to replace the pump.
Anonymous
  • Posted on Jun 22, 2010
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Siemens Siwamat 276 washing machine not agitating
My first thought was that it was a problem with the drive belt or tensioner, but if it spins, that can't be the answer. That points to a main board or motor controller problem. In the first instance try a Power Reset. Disconnect the machine from mains power for a couple of hours, or preferably overnight. Press and hold the power button for 30 seconds and then plug it back in. If that doesn't fix it, you need a service call. It doesn't appear to be a known issue.
https://www.google.com/search?q=Siemens+Siwamat+276+front+load+washing+machine+not+agitating
How do I use the washer and dryer on Siemens siwamat xs 1047
put clothes in,put soap in,choose hot or cold,choose what cycle,press start
Siemens siwamat 283
Time has passed but maybe this can help someone:
https://www.dropbox.com/s/sy204p9fexze160/Siwamat_283.pdf?dl=0
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
2helpful
Siemens Siwamat XL1480
there is a large possibility that the water is not able to be pumped out in between the rinse cycles therefore I would get a friend to blow down the water outlet pipe to check if its clear you should be able to tell if its so, or the water pump is jammed or brocken hope this helps a little eric
Top Siemens Washing Machines Experts
vince
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
