SOURCE: Towing capacity
Directly from the Toyota Spec Book:
Maximum trailer weight: 1,500 lbs
Maximum tongue weight: 150 lbs
Hope this helps; and, thanks for choosing FixYa!
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
SOURCE: magnetic resistance not working on proform gl105
Just oil the area of magnetic resistance and if the problem continues then contact nearer repairer.
SOURCE: what is the maximum weight capacity for the Honda
look on the vin sticker(most likley on the steeting head on the frame) it will say GVWR, this is the max carry capacity. also the owners manual will give specifics as to the distibution of that weight.
