Fuses blow when the is an overload on the system. Regardless of any settings. Most likely the power amp section of the right channel has a shorted semi-conductor(s) somewhere. Replace that and the replacement fuses should be OK.
You do need to check the speakers and wiring on the right channel, plus the connections. Anything wrong there will cause a failure of the replaced parts again.
SOURCE: EV sonic XS 4.1 computer speakers and amp
Hi CarrieBeth
depending on the brand of your speakers (creativelabs) etc, have different models, but some of them have problems with AMP, and subwofers. Send me your brand or model, to help you out more direct, or depending on the brand, some models lile 5600 from CL. have problems on the AMP module on the sub. have to change or fix the AMP chip.
hope I can help
Carl
SOURCE: Microwave keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
SOURCE: keeps blowing fuses
This problem is just like my own microwave, replace the shorted HV capacitor
SOURCE: Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
