Question about Bosch Axxis WTA 3510 Electric Dryer
Dryer often squeaks during operation
I've got a 4 year old WTA 3500. Great little machine. However, it has recently developed a squeak. It doesn't squeak non-stop for each use but does squeak each use probably for about 50% of the time it runs. I've tried to isolate it to no avail.
Has anyone had a similar problem?
  • 130 Answers
Addison your issue is with the rear panel. The 3500 was the first generation of this unit. The rear support of the drum goes thru the rear panel and this has bent in. Order a new rear panel and this should resolve this issue.
Posted on Jan 06, 2008
  • 482 Answers
It may need oiled, or a new belt.
Posted on Nov 26, 2007
I need to remove the front panel of a GE WSM2700 Electric Dryer
Here's a great guide for your needs.
Has all the info plus pictures
Dec 29, 2012 | Dryers
Maytag dryer model number LDE840ACE squeaks during the drying cycle
That is probably a Wheel. More likely the wheel over the heater. I recently worked on one of these and posted a pictorial:
My Maytag dryer repairs
Jun 20, 2012 | Maytag Dryers
I have a Frigidaire Gallery Series dryer that has developed a squeek when drying. The dryer is about 3 years old.... and doesn't do it all the time
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 27, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer just started making a loud growling sound while in operation. Prior to this, it had begun to take extra long to dry a load of laundry. The dryer is about ten years old.
Jul 06, 2011 | Bosch Axxis WTA 3500 Dryer
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
Feb 26, 2011 | GE Profile DPSR475GW Dryer
My 15 year old Amana Heavy Duty Washing Machine (top loading) has developed a very bad squeak during the wash cycle.
sorry its the clutch and trasmission its going out either repair or replace the washer my wifes washer started doing the same thing somedays it did fine and others times started squeaking.
Dec 22, 2009 | Washing Machines
Maytag Dryer, 25 year old dryer has a loud squeak
The squeaking is coming from the rollers that the drum rides on. If you take the model number to a local appliance service store they will have the parts and be able to direct you on replacing them.
Jul 20, 2009 | Maytag PYE2300AY Electric Dryer
Intermittent Squeaking
You know how when the pads on your car get worn they start that noise? Well the bearing that holds the tub has a metal bracket. When that plastic wears down it begins to makes those noises. If left alone the metal bracket will eventually cuut into that drum bearing like a guillotine. I have pictures. Have the women and small babys leave the room: Click (HERE)
Jul 08, 2009 | Frigidaire GLER341A Electric Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
Sep 17, 2008 | GE Profile DPSR473EW Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
217 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
