Question about Kodak Cameras
How do I take a Kodak ZM 2 apart to repair the usb port
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Bad USB Port in Camera
I think you CAN--there's a lovely site with specific instructions,,,, Do It Yourself Camera Repair --- for fabulous step by step instructions WITH pictures & simple explanations that a novice can follow!!!
In short, all you need to do is find another USB port (even from a broken camera or other device) to replace yours. It seems that you'll need to solder it in -? - that's the step I'm trying to research right now--I'd like to just glue mine back in because I don't know how to solder--- but the tricky part is getting the camera apart, not touching the flash capacitator nor any of it's power-holding chips, and not damaging any of the other components.
(ACF0EB8F)
Posted on Sep 15, 2008
Kodak scanner i3400 error e73
e73 is A USB command failure. Check to see if the scanner is connected to a USB 3 port. A USB 3 port can be identified by the port being Blue in color or have the letters "SS" (Super Speed) near the port. Kodak scanners behave strangely with USB 3. With the unit turned off, please connect the scanner to a USB 2.0 port. Additionally, download and install (as an administrator) the most current drivers from Kodak.com which alleviates 9 out of 10 issues.
Apr 04, 2014 | Kodak Office Equipment & Supplies
Kodak Z1012 IS camera into usb port will not send pictures to my computer or my documents.
hi let me save you pocket. Instead of repairing your camera would be economical in this issue. you just buy usb memory card reader about $10. you put your sd card into the reader and connect to computer. That is easy. you click on my computer, you will see a new drive folder. rest of work is yours...However it will cost to you if you want to repair the problem. your camera might has usb port defective and local repair shop would charge around $65 to 125 depend on what they really want to charge. thanks and best regard!
May 23, 2011 | Kodak EasyShare Z1012 IS Digital Camera
Where do I put my usb wire in my computer 2 charge my phn?
Any usb port available in the computer, it does not mattery which USB port it is.
Mar 06, 2011 | Kodak EasyShare M530 Digital Camera
Does my acer 5535 have a webcam
According to the specs. it does not have a WEBcam.
This is the specs.
Aspire 5535 Series Specifications
Part Number: Aspire5535 Aspire 5535
Feature Description Part Number Varies by specifications Processor / Speed AMD Turion™ X2 Ultra dual-core mobile technology ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1 MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology. Core Logic Chipset AMD M780G Chipset. System Bus Speed 667 MHz. RAM / Max RAM Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules. Video Subsystem ATI Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of dedicated system memory, up to 1792 MB of shared system memory), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.0, Microsoft® DirectX® 10.0. LCD Properties Display 15.6" HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time. Hard Disk Drive 120/160/250/320 GB or larger hard disk drive. Optical Drive 8X DVD-Super Multi double-layer. Battery, Primary 48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use. Sound Subsystem Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone. PCCard Support 1 ExpressCard™/54 slot. Pointing Device Touchpad Peripheral Subsystem ExpressCard™/54 slot.
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model) Dimensions / Weight 15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack. AC Power 100-240V AC AutoSensing Adapt
Dec 23, 2010 | Acer Computers & Internet
Can i charge my kodak M341 using usb port using a pc.
Yes, if the computer puts enough juice into its USB port; not all computers do. If you have ports on both the front and back of your computer, try the back. Otherwise plug the USB cord into the wall charger supplied with the camera.
Apr 18, 2010 | Kodak EASYSHARE M1063 Digital Camera
Why can't import my pictures into the computer?
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable
Turn off the camera.
2 Plug the labeled end of the USB cable into the USB port on your computer.
3 Plug the other end of the USB cable into the USB port on the camera.
4 Turn on the camera.
Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
With that amount of non-accidental damage, a replacement is the best option financially
Mar 05, 2017 | HP E427 Digital Camera
(ACF0EB8F)
Aug 18, 2008 | Kodak EasyShare DX7440 Digital Camera
Kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
www.kodak.com/go/usbcharging
Feb 13, 2008 | Kodak EasyShare M853 Digital Camera
Cameras Logo
48 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
