The Model is an LG 60PM670T 60" TV I have changed the control board and the ZSUS Board and am waiting for Two Y Buffer boards to arrive and i thought it was time to see what thoughts are out there as to what the cause could be....Many thanks for any replies.
SOURCE: Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
SOURCE: LG "NO PICTURE" , IF FIX WILL RECUR? ,DID LG FIX DESIGN FLAW 42PC3D
I had same problem - no picture, but sound worked - LG 42PC3d - was two months past warranty, but LG agreed to fix it as a warranty call. Service guy was out within a week to replace the Z SUS(?) board. Works fine now. This must be a typical problem, as LG did fix it, even though the warranty had expired. Good luck.
SOURCE: HDTV backlight turn off after 10-15 minutes, with some t-shooting
I have read everything I can find on the net about this problem for Polaroid TLX 04240b TVs (most, like mine, bought from Wal-Mart on Black Friday after Thanksgiving). I thought I was on a hot lead when I changed a 220uF 450v capacitor, but I still had the same problem. I saw a short post from somewhere else on this Fixya web site (sometimes I can find it again and sometimes I have trouble locating it) that said someone flipped a tiny switch on their circuit board and the problem was gone. I did the same thing and my set has been working fine. They had said their set was on for over 8 hours two days in a row when they posted. The other night my daughter left our set on over night for 20 hours and the picture still was working great. If you look through the top of the set when the picture is on you can see some white light at several locations, when the screen goes blank the white lights go out and a red LED light can be seen. If you take off the plastic cover on the back (3 screws) and then take off the metal cover (3 screws) this red LED light is on the upper circuit board in the lower left corner. Just a little to the right of the LED light is a small switch block that has 4 tiny white switches. I turned my set off and took the bottom switch (#4 and had the letters BURN by it) to the right "ON" position, turned the set back on and, so far so good. PLEASE NOTE!!! I know almost nothing about how transistor circuits work. I have no idea what the switches do or what long term effect this might have on the set. The set was only good as a paper weight before so even if this only fixes the set for a short time it was at least worth a try for me. Does anyone know what those switches are supposed to be for????
Testimonial: "Great information, thanks! "
SOURCE: LG 42PC3D ZSUS Board Location
the z sus board is the board thats on the right next to the right speaker looking at it from the back, and you can get it at ebay cheap.
