Question about Arris SBG1000 Wireless Cable Modem Gateway Router (493989-001-00)
Can't log into my router
Using the SBG1000 router, but i can't login with the default login info. Is there any way to reset the info without resetting the entire router?
  • Avzzz Aug 16, 2008
    What is the default username and password for the SBG1000 please ? I had used it in a different country for a year with the local broadband provider having installed this. I have moved countries and want to use the cable modem. Dont know how to login as dont remember the previou login/pass. Can i reset adn use some default ? Any pointers please ? Thanks
Even after resetting the router with a hard reset. Still no access to the router thru wireless period. Only thru cat5 patch cord.
Posted on Oct 28, 2008
    Problem Solver:
  • 6 Answers
No there is not a way to just change the password on these devices. If you have changed the password from the default and either forgot it ,or fat fingered it upon entry then you will need to do a hard reset which resets everything. However the config's on these are so simple it shouldn't take longer than 10 min to reconfigure it, especially if you have good documentation!
CNA, CNE, MCSE, CCNA, Network +
Posted on Nov 26, 2007
How do I reset my netgear wndr 3700 without using the factory reset button
Known as a soft reset online at the routers IP address...sometimes you can get there by typing but it should be on the outside case of the router.i.e. and then login in with default user : pass also shown on case.observe upper or lower case.usually admin:admin If no info on case just google default router ip etc for make and model.then once in settings ...reset
Feb 18, 2015 | NetGear WNDR3700 Wireless Router
I forgot my password to my router i connot log in
There might be info in your routers user manual to reset the router, then the login will be the same as the factory default and you can login and reconfigure it all over again including changing the default password to your liking.
May 13, 2014 | Computers & Internet
I am trying to login as admin, to be able to change the default password and secure the signal, but the default username does not let me log in. I'm using, login-admin, password-(blank). H
Looks like you wil have to do a facotry reset. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 14, 2011 | D-Link DIR-615 Wireless Router
I lost my access code
If you lost the wireless access key you can find it by logging into your router. Using an internet browser type into your address bar. A login window should pop up. The default login is username: admin password: admin . If these do not work then you need to reset your router to factory defaults. If this does work then look for the place where you can change the key and change it. You may need to reset the router after this for settings to take effect but after that it should work.
To reset to factory defaults, look for a button on the back that says reset. Press and hold this down for 30 seconds. Everything should reset to factory defaults and you should be able to connect without a password.
May 12, 2011 | ASUS RTN12 IEEE 80233u IEEE 80211bg...
Log in admin linksys
By default, there is no username and the password is 'admin' without the quotes.
If you are unable to login using those credentials you might consider performing a hard reset. This will erase all settings, so you will have to reconfigure the router.
To reset:
Hold the reset button, located on the back, for 30 seconds
While still holding the button, pull the power cable, wait 30 seconds
Continuing to hold the power button, plug the power back in
After 30 more seconds release the reset button
Let the router sit for a few minutes, then try to login
The above procedure is often referred to as a 30-30-30.
Mar 02, 2011 | Linksys Wireless-G WRT54G Router
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
Need to know username and password
If you forgot your router password,you will have to reset the router back to factory defaults and log in using the default password.-->
To restore the factory default configuration settings without knowing the login password or IP
address, you must use the Default Reset button on the rear panel of the router.
Connect to the wireless router by typing or the router's LAN IP
address (default is in the address field of your browser and then press Enter. A
login window opens:.
Enter admin for the router user name and your password (or the default, password).
For more details use the netgear instruction manual--->HERE!
Jan 03, 2011 | NetGear WNR834B RangeMax NEXT Wireless-N...
Where can I find the password/key for my netgear wireless router
Do you mean the key to log onto your wireless network? Plug a computer directly into the wireless router via the ethernet cable and go to or Internet Explorer. I believe one of those default address for netgear routers. Login to the router, the default login is login:admin password:password then select 'wireless settings' on the left and you should see the key.
If any of the default info has been changed and you cannot login, you will need to reset by pressing the reset button for 30 seconds. But you will have to reconfigure the wireless network and reconnect all computers that were previously connected.
Nov 06, 2010 | Computers & Internet
How can we open the router configuration without password.......& usernane
Dear Friend,
If you don't have change your password from factory defaults then look into manual for user name and password...
If you have change your password then, Sorry you have to reset your router. this will delete all your configuration but will set your login id and password to factory defaults... ( there is no other way)
Please rate the answer
Jun 08, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I need pin number for my Belkin router F5D7234-4 v-1000
If you have forgotten your WEP Key and need to start over you will have to reset your router. On the back
The "Reset" button is used in rare cases when the Router may function improperly. Resetting the Router will restore the Router's normal operation while maintaining the programmed settings. You can also restore the factory default setting by using the "Reset" button. Use the restore option in instances where you may have forgotten your login password.
Push and release the "Reset" button. The lights on the Router will momentarily flash. The "router" light will begin to blink. When the "router" light becomse solid again, the reset is complete.
Restoring the Factory Defaults
Press and hold the "Reset" button for at least 10 seconds, then release it. The lights on the Router will momentarily flash, The "router" light will begin to blink. When the "router" light becomes solid again, the reset is complete.
Configure the Router Using the Web-Based
Using your Internet browser, you can access the Router’s Web-Based
Advanced User Interface. In your browser, type “” (you do not
need to type in anything else such as “http://” or “www”). Then press
the “Enter” key.
Logging into the Router
You will see the Router’s home page in your browser window. The home
page is visible to any user who wants to see it. To make any changes
to the Router’s settings, you have to log in. Clicking the “Login” button
or clicking on any one of the links on the home page will take you to
the login screen. The Router ships with no password entered. In the
login screen, leave the password blank and click the “Submit” button to
log in.
Jan 31, 2010 | Belkin Computers & Internet
Arris SBG1000 Wireless Cable Modem Gateway Router (493989-001-00) Logo
559 people viewed this question
Top Arris Computers & Internet Experts
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
