Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens auto focus sometimes does not work.
Not sure why this lens sometimes does not autofocus. I try to focus on my subject, the lens focus move left and right and will not focus on my subject. I have no problems with my other lens. In order to solve this problem, I have turn to manual focus. Just got my len over a year ago.
I'm afraid I have to take this to canon shop, hopefully there is a solution. changing the battery on my camera does not help either. Thank you.
    An expert whose answer gotĀ voted for 100 times.
  • 206 Answers
Re: lens auto focus sometimes does not work.
First make sure contacts on lens are clean ( see enclosed pic #2 ) . If this does not solve the problem the ultrasonic motor may be faulty pic #1.( sometimes switching on but sometimes not , will have to be replaced , unless there is a bad connection between the motor and lens pc board )
Posted on Nov 26, 2007
0 characters
3 Points
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
I have a Sigma 24-70 2.8 EX DG Autofocus will not work.
Call Sigma. Here is the information. They will be able to help you for sure. To request assistance by phone in the US, their technicians are available from 9AM to 5PM Eastern Standard Time, Monday through Friday. Please call: (631) 585-1144.
Customer Service Department call toll free (800) 896-6858.
You can also fax them 24 hours a day.
Fax: (631) 585-1895 or (631) 585-7661
Jan 25, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
Hi there, I don't know if it's a problem or not (I can live with it :) ). I just got a Canon EF 50mm f1.8 II lens, and I really love it. But: When I'm using the eye-level viewfinder (and not...
You may just have the left auto focus points selected. You don't say which camera model you have. If on the back of your camera you can see a button with an icon showing 5 small white blocks in a plus sign in a white box press this to select the auto focus points. It should show the available auto focus points and then use the left/right (wheel) button to change the selection
Jul 01, 2011 | Canon EF 50mm f/1.8 II Lens
Auto focus not working?
1st u reset the factory setting and then u see the lense is correctly fitted or not and the autofocus option is working or the manual focusing is there or not
Dec 14, 2009 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Auto Focus not working for Canon EFS 18-55mm lens
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
May 30, 2009 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Camera Lenses
Slight blur shooting variety of subjects
It is just a possibility but you may have overrode the auto focus. If you accidentally move the focussing ring it disables the auto focus.
Mar 17, 2008 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
I would send it into sigma. They are in NY,
They are really quick about checking things out and I have neverhad them charge me to look at a lens and tell me whats up. aot of times they will just fix it while it there is it looks like something is worn out from normal use.
its a great lens. Some would say its a slower focus. than the Canon brand and you do get what you pay for but its hard to spend as much on canon lenses as they want. :)
Hope that helps,
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
411 people viewed this question
Top Canon Camera Lenses Experts
Are you a Canon Camera Lens Expert? Answer questions, earn points and help others
