Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Horizontal lines on NEC plasma
By lucyh1515 on Nov 26, 2007
I have an NEC 42 inch plasma. 2 days ago horizontal lines have been travelling upwards on the screen. Any idea how this has been caused or how I can fix this? Thank you
Same Problem
May 10, 2009
-   Yes, I have a Sharp 32", I have vertical colors travling on my screen. It now takes, 20 minuts, befor I get a picture working. It"s a little over a year old.-   pcpilot
Feb 19, 2009
-   I have a Samsung HPT4254 720P 42 Inch Plasma HDTV That is NEW! Had it for about barly a year. And no warrenty.It turns on and the sound works. But it has white and black Horizontal lines all over the screen and thats all you see. I called Samsung and they said they couldnt help me. I said well give me back my 1,200 back then A HOLE! :0 I will never buy a samsung product again.-   Shwmesumsk1n
Feb 19, 2009
-   I have a Samsung HPT4254 720P 42 Inch Plasma HDTV thats NEW! but out of warrenty. When i turn it on i get white and black horizontal lines all over the screen. Samsung said they couldnt help me i was like wtf you mean you cant help me. Give me back my 1,200 then A HOLE! :0-   Guest
Feb 02, 2009
-   I have a Harsper Plasma 4200 PDP Monitor and the screen is really fuzzy. Is there a cure this? I just bought a few years back.-   brad1446
Jan 23, 2009
-   picture normal for 1hr then afterwards the picture getting red every 15mins and with vertical line in the middle of the screen
-   larry_avena
Best Solution
posted on Nov 26, 2007
Helpful)
diazphi
Rank: Wiz
Rating: 80%, 267 votes
Intermittent horizontal deflection
Resoldered the pins of horizontal deflection transformer
Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Geometric distortion, Pillow, and picture enlarged horizontaly
The problem was a short from GND to pin 11 inside IC301 (TDA8350Q). This pin is the output of amplifier for geometric correction signal. Replace IC301
Comments:
Nov 26, 2007
- You rate me Helpful maybe the preparation was not meet your requirements to troubleshoot your problem It is possible not to give up everything I think you need warm up to pickup everything under sun.
Just follow my advice to look for an expert to settle down your problem. I hope you can find a good technician to replace the given tips to prove my expertise does not good enough information I give but it just too simple to follow rules.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Is the Apex ld4088 a realiable set?
Answer
trying to find ot who makes vivo plasmas
Answer
we have a 50 inch 720p Panasonic HDTV. While watching, the tv randomly turns off, no sound and the... (More)
Answer
Can't remove the disc from DVD played
6 Other Users Have The Same Problem - Continued
Comment by TASSEL15, posted on Jan 05, 2009
HORIZONTAL LINES ON MY FLAT SCREEN TV.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
