Hi, can't find that error code , do you mean 24 ?
What joystick ( controller ) is fitted ?
https://www.quantumrehab.com/quantum-electronics/ne-controller.asp
Regards
Rob
SOURCE: Its Quantum Q6 edge. I got this error today. Please tell any solution.
First, I'm not a Quantum epresentative.
* Check your warranty. Call for support.
USA:Pride Mobility Products Corporation
Attn.: Customer Care Department
182 Susquehanna Avenue Exeter, PA 18643-2694
[email protected]
1-800-424-8205
*** Following is for information only.***
* Manual; https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q6_edge_om.pdf
* Follow guidelines in manual (especially charging and maintenance)
* Check your fuse.
* As with most Lead Acid battery systems. Care must be taken to assure long life.
* Lead acid batteries have a cycle (recharge) about 200-500 cycles.
* Example, if you charge every day that's 1 cycle per day for 200 to 500 days. Depending on how hard you drain the batteries, charge times, and how hot it gets where you store it.
* Here in Hawaii, most car batteries last 2-3 years tops. For power chairs it's less. (I suspect it's due to having lots of hills.)
* You will need to check the status (Health) of your batteries. (Take it to the shop to test. Battery shops can test it too.)
Aloha, ukeboy57
