Question about Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 and it wont charge
I have a dell inspiron 1525 there is nothing wrong with the charger and i just bought a new battery but the problem is my computer wont charge i don't know what to do
  • Jon Hunter May 11, 2010
    If you are still having this problem it may be due to the sensing pin on your laptop. The 1525 and many other Dell laptops use a 3rd power supply pin to sense that a Dell adapter is present and to avoid damage to the laptop/battery. Unfortunately the sensing line can break on the power/USB connector board so the laptop will run from AC but not charge the battery. In the BIOS battery check it will show that you are not using a genuine Dell adapter even if you are.. If this is the case let me know and will give the rest of the details on the repair.
  • Winnie The Pooh Aug 08, 2013
    Jon, can you post the details for repair? Thank you.
    Sergeant:
  • 175 Answers
If possible could you check output voltage of the charger with a multimeter? If you can get output voltage, then might be something wrong with laptop battery charging circuit. Contact Laptop Repairing Engineer.
Regards;
Hassan
Posted on Aug 04, 2009
SOURCE:
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
MY DELL LAPTOP SAY 0 % NOT CHARGING
Take it back to where you bought it from for testing.
Try putting charger in a different power point.
Dec 12, 2012 | Dell Inspiron 1525 Laptop
Why wont my new battery for my Dell Inspiron 1525 fully charge?
Contact whoever sold you the new battery and ask for a replacement, or for their technical support, (if they have support).
-a.
Jul 28, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
I've recently bought a new charger for my dell inspiron 1525. The green light still shines when its plugged in, but it doesnt appear to be charging the laptop itself. Before, i would have put it down...
enter the bios with F12 and battery status somewhere, you have to see if the battery is charging.
1 - if you do not recharge the battery, you can try a new battery if the battery schimnabata no (new) option 2 then it does not load.
2 - is necessary to change the motherboard, because the battery charging mode does not function normally.
warranty if you go to them to do.
Feb 12, 2011 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
Dell Inspiron 1525 battery problems.
try removing the battery and turn on your laptop, then while laptop is on, slide in the battery.
Apr 18, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Battery good charger good but not charging the battery dell inspiron 1525 laptop
Update the BIOS that will be the best recomendation if it wont do good call dell support
ERNZ
Feb 03, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery quit charging when warranty quit. Bought new charger, didn't help. Told motherboard needs replacement? This seems fishy to me. What kind of laptop works longer than the...
It is possible the battery itself has wore out. They have a limited amount of time they can be recharged. Does the unit run while the charger is plugged in??
Jan 26, 2010 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Notebook Logo
398 people viewed this question
Clive
Clive
Alun Cox
