Question about Motorola Mobility RAZR V3
Cell phone my cell phone fell out of my pocket and into the toilet. the bottom half is working just fine but the screen is blank. Will i just have to let it dry out and can i help this process? I have the razr-v3 cell phone, the bottom part works but the top part the screen  is just black.  It didn't fall in a toilet or get wet in any way, so if anybody has a solution for me out there please help. Thanks you from Cisco.
  • 31 Answers
Re: cell phone
If the phone didn't get wet or u can't see a visibly broken screen then ur lcd may still be working, u simply may need to re seat the ribbon cable that connects the lcd by un screwin the 4 screws that hold the display n pryin in open from the mid section of each side then use somthing flat to lift the connector n replacing it pressin firmly.
Posted on Nov 26, 2007
0 characters
3 Points
Phone fell in water
If it's at the point where the screen isn't working properly, it's dead. If you have some kind of extended warranty, it may cover it, but there's no real way to bring it back from being water damaged, unfortunately.
Jan 25, 2014 | Samsung Galaxy S GTI9000 Smartphone
My lg neon phone fell in the toilet
dont turn it on, motherboard need to be cleaned in the isopropanol, if you dont have it just let it dry (put it into the cup with rice for few days) DONT TURN IT ON (at least for 5 days if you not sure if its dry) Use hair dryer from long distance to dry it. Even if you think that phone is dry it will be still wet. Your battery can be dead as well as screen. But if you are lucky it will work.
Oct 21, 2011 | LG Neon GT365 Cell Phone
Razr phone just fell out of back pocket into toilet. I took of back cover & removed battery. What next?
Dry the phone, battery, sim card, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 19, 2010 | Motorola Mobility RAZR V3
I dropped my sidekick 2008 in the toilet
really the only thing to do in this case is to let it dry COMPLETELY before putting any power to it. if you let it dry completely now it may still work but if you tried it already and it failed i doubt it. try a new battery if it wont turn on. i dropped my nokia in the toilet and let it dry for 3 days then it worked; had a buddy spill his bottle of beer on my blackberry and after the defrost and over night it worked fine.... good luck
Apr 26, 2009 | T-Mobile Sidekick "Gekko" cellular phone
Dropped my K850i in water about 6 weeks ago. phone has completely dryed out but won't switch on. any guesses?
water might have entered inside your phone and so you have to contact near by sony ericcson repair shop because droplets of water might have damaged board so you need proper cleaning
Jul 10, 2008 | Cell Phones
Nokia N70 fell in the toilet
Its better not to use it because even if it be repaired this will not be reliable.
best solution ?
please dont forget to vote if you consider my suggestion helpfull.
Dec 28, 2007 | Nokia 7260 Cellular Phone
L7 water damage
I dropped my phone in the toilet when it fell out of my back pocket. The best thing to do is dry it as well as possible and then leave it out to dry. I let my phone dry for approximately 2-4 weeks and now it's working again. I found this out after I went out and bought another phone. LRL from Texas.
Nov 17, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cell phone
sorry but oncce they get wet they never work the same again
It may come to life if you leave it dry a little while longer but the damage is done
You will find if it starts to work again that all sorts of faults will occur as time goes bye
Nov 17, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Messed up my phone bad....
You need to take the battery out and let it dry in the sun or a warm dry area for several days. DONT PUT IT IN THE MICROWAVE, OR THE DRYER!!! Although, not removing the battery immediately, may have damaged it permanently. Best of Luck.
Sep 14, 2007 | LG enV VX9900 Cellular Phone
Motorola Mobility RAZR V3 Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
