I just installed a new filter. I have water to my ice maker but no water out of the water dispenser. I took apart the coupling under the door and i get water to there. Is there another solenoid inside the door. What could this be?
Alex
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
The water line is frozen inside the door. very common ge problem. you can defrost the dispenser area with a hair dryer. it takes about 30 min to do. it will freeze up again. if the frig is less than 3 years old, even though it out of warranty you can argue with ge and youll get a new door to fix the problem
