Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Rotary water spray device on roof of d/w has popped off - does not appear to be broken but a plastic piece inside location where spray device is connected appears is loose and moves around Can I fix this myself William
  • Tley Mar 17, 2008
    Trevor
  • Ron Coons
    Ron Coons May 11, 2010
    you certainly can please give entire model number ill look up the part number. easy repair
    Sergeant:
  • 409 Answers
Most spray arms are easily fixable. they are held on by screws or brackets. you can just put them back yourself. sometimes they come loose due the vibration caused by the dishwasher operation.
Posted on Sep 13, 2008
Roof leaking on 2003 breckenridge camper
Most roof ac units sit on a seal that fits around the opening outside, and on the inside there should be 4 long retaining bolts that that have or go thru some brackets, that squeeze the unit down. Kinda "sandwich's" the roof, if you will. I've simply tightened these 4 bolts carefully, and stopped the leak. Or the seal is damaged. And it also may be the drain. The opening will be under the plastic shroud. With the shroud removed you should be able to see a small opening near where its wet on the roof. I normally spray quickly with water at the opening. It normally clears easy. Condensate drain or weather seal.
Jun 27, 2015 | Heating & Cooling
2003 STS cadillac leaking water on both driver and passenger floor boards
It could be the sun roof. It also could be clogged drains from the sun roof. It may also be door seals Leaking. It could also be leaking around the bottom of the windshield. A good way to narrow it down is to get inside the car and have someone spray the outside of the car with a water hose. while you look for water leaking inside of the car. If it does it while the ac is on may be a clogged ac drain. however it usually just leaks on passenger side when it is that. well good luck.
Jan 13, 2015 | 2003 Cadillac Sts
Where is the water coming from under the seats in my 2001 MR2 Spyder?
Your roof is leaking there are a couple of plugs that are under the seat that will help in draining the water. Move the seats all the way forward and put the backs tilted forward you will see a piece of plastic that looks like a drain that's one of the covers be gentle as they will break best bet is to get a repair manual for this type of repair as instructions can be done in several ways also then you are going to have to find the leaks you may not see them when driving as they are probably rolling down the back into the roof storage area but if you spray one area at a time also tape around the edges and see where they get the seal broken if its just a leak with the roof suggestion is to let pro handle it as they can restitch or possibly glue top. But it is definitely the roof you can also try the drains in the jamb you will see them as they are just rubber or plastic plugs again be gentle or you will have to buy new ones.
Jun 09, 2014 | 2003 Toyota MR2 Spyder
Internal water dispenser rf266ab rubber cover came off and it appears there is a piece missing that holds the plastic piece down to dispence water
Had same problem. Ordered a part that appears to just snap in and replace the broken water dispenser face at this website. http://www.repairclinic.com/PartDetail/Dispenser-Actuator/DA9704952B/2049390
Apr 19, 2012 | Samsung Refrigerators
How do I repair stuck chuck
Sometimes it just needs some lubrication inside where the ball holds onto the bit. If that doesn't work, you need to replace the chuck pieces. Often times they come in a kit. The plastic sleeve may need to be cut or broken off.
Apr 07, 2012 | Drills
F150 sunroof will not open
is it the plastic slides with wire on them that connect ot the drain trough? May not be serviced separately. they are available for 2003 Expedition. Don't know if similar.
Drive Cables and Guide Rails Disassembly and Assembly
  1. Remove the roof opening panel frame. For additional information, refer to Roof Opening Panel Frame in this section.
  1. Remove the roof opening panel water trough.
    1. Remove the bolts.
  1. Remove the roof opening panel water trough guide by sliding it forward and lifting it outward at the notch in the roof opening panel tracks.
  1. To assemble, reverse the disassembly procedure.
Dec 16, 2009 | 2001 Ford F150 Styleside SuperCrew
I have a broken plastic piece on my 01 Expedition Moon Roof Am I totally SCREWED?? Ford says new moon roof $$750
you have several options so do not feel screwed yet. first of all if you have the broken piece you can use clear epoxy and permanently glue it back together. Also, you can search on line or call a junk yard for the part you need.
Aug 17, 2009 | 2001 Ford Expedition
1995 C220 SUNROOF NOT SEATING PROPERLY
Unfortunatly these roofs are basically a complete unit with cable and frame all in one unit where as previous roofs had replacable components. Assuming yourr roof seal is not torn or damaged you can adjust the glass somewhat. There are 6 torx style bolts that secure the roof to the tilting brackets. I would raise the roof in the pop up position and carefully remove the side bellows(They are also a common failure and can cause roof to bind or not operate to complete rest postion)-they pop out by pulling outward. Just remove the bottom section so you can easily reinstall them. Next loosen the back torx screws( I beleive they are size t20) and push roof up as far as you can and resecure. If only one side is not popping up as far as it should just do that side. Then try resynchronizing the roof parameters by pushing the button untill roof is in forward postion and hold for approximatly 10 seconds-next push button untill roof is in pop up position and hold for 10 seconds. You can also loosen all 6 screws by popping off the plastic trim piece in front of roof and loosening the screws and pushing roof all the way forward. but you will spend alot of time adjusting utill roof is perfect. good luck
Aug 04, 2009 | 2002 Mercedes-Benz C-Class
Junk inside spray arms stopping them up.
Every once in a while, run it with powdered lemonade inside. It'll cut down on your lime deposits. It works. Just dump it inside. No need to put it in the resevoir
May 20, 2009 | Dishwashers
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
81 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
