Question about Kenmore 22422 Top Load Washer
Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
My washer is not holding water. HELP! when i say not holding water i mean it goes in and right back out and does not stay in, not even a little.
  • 213 Answers
Re: Kenmore 70 series Model: 22702 100 Series CL2738136...
The drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Posted on Nov 27, 2007
0 characters
3 Points
Hot water continually runs into machine (kenmore 70 series type 111 mod # 110.26732500 ser# c823109162
The water valve has failed in the open position - or there is sediment blocking it from closing fully.
CLICK HERE to see a replacement water valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2010 | Kenmore Washing Machines
Washer Kenmore 70 Series Model # 110.247323000 Serial# CR3845255 Type 111 Washer fills cold, warm, hot - no agitation - no draining
Jan 12, 2010 | Kenmore Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Apr 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washer won't Agitate
gearbox internal fault, major repair, not really a do it yourself job.
Dec 25, 2007 | Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
542 people viewed this question
Richard Roth
Richard Roth
Jesus  Colon
Jesus Colon
Level 1 Expert
Fred Sops
