Question about Solis Master 5000 Espresso Machine
When I put the machine in froth mode,, there is very little pressure coming out. I was wondering if it was the pump that needs replacement.
  • Solis Expert
  • 223 Answers
Try descaling your machine, because it may be clogged. Boilers heat up the water to produce steam. If descaling doesnt work you may have a boiler related problem.
Find descaler on
Posted on Nov 26, 2007
How can I determine what parts I need to repair my espresso machine and where do I get parts and service?
Solis Master 5000 Espresso Machine - YouTube
? 9:49 Sep 2, 2010 - Uploaded by Day Tooley
I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
Nov 03, 2015 | Solis Master 5000 Espresso Machine
I have got a master 5000 and the brew unit gets jammedor locks when goes on brew mode.
There are a couple (3) of things that can cause this.
1. You have a broken brew drive but you would hear a clicking noise if this happens.
2. You have an over charge going into you brew unit. There is a small knob in your bean hopper. Turn it back 1 mark and try again.
3. Your grinder has come apart and is grinding very coarse. (French press size) New grinder.
Jun 01, 2011 | Solis Master 5000 Espresso Machine
No water supply on Solis Master 5000 Manual
open steam valve and run water couple minuts,after try again if light show up again thats mean machine is somewhere clugged
Aug 23, 2009 | Solis Master 5000 Espresso Machine
Solis 5000 diagram of brewing unit
See for technical documentation of the digital unit (brew group looks the same as the non-digital one). Descriptions in German, French and English.
Mar 26, 2009 | Solis Master 5000 Espresso Machine
Solis master 5000 Espresso Maker is leaking
Before you go that far, what does the grind on the coffee puck look like; is it fine like powder or is it course. The water from the machine might not be able to go through the coffee and so the bypass is opening because of too much pressure. Try adjusting grind first.
Mar 24, 2009 | Coffee Makers & Espresso Machines
Solis Master 5000 Leaks Out Bottom in Priming
More than likely the boiler is leaking from improper descaling. Seals do not dry out but they will become hard and brittle if you descale while the machine is hot. I would say you need your boiler replaced. Another thing that will make your boiler leak is not descaling it on a regular basis.
Mar 11, 2009 | Solis Master 5000 Espresso Machine
Grinder not working on my solis master 5000
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
Good luck and Best wishes
Dec 19, 2008 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine - Need Repair
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Apr 21, 2007 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine Logo
122 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
